Couple of 2nd Gen Rodeo questions #769508 12/04/06 09:59 AM
4
4Play Offline OP
I have a 2000 Rodeo LSE, 3.2 V6, 4wd, 85k miles, orignal owner, see sig for mods.
Okay Im getting back into wheeling my Rodeo after a couple of offroad mishaps. 3 problems I can't figure out:
1. Rear Defroster: Only the top 1/3 of the window defrosts.
2. When parked on my driveway (inclined, but nothing crazy) The fuel guage drops all the way down and the fuel light flashes. This will happen with the tank over 3/4 full. No fuel leaks out and the guage will return once the truck is level.
3. Overheating: When in traffic regardless of outside temp. During hot weather anytime I drive more than 30 mins regardless of speed. I had my radiator flushed and thermostat checked but the problem still remains.
The Rodeo was just at the dealership and they didn't notice anything w/ their safety inspection.
Any help would be great!
Thanks,
Ashby
'00 Rodeo LSE 4WD, 3.2, Black, LSD, OME 919s w/ 2in Spacers, Superwinch Hubs, RS9KXLs, Indy4x steel braided brake lines, LT 265-75-16 MT/Rs, ShrockBars, DOR HD rear Lat. Bar, MagnaFlow.
Re: Couple of 2nd Gen Rodeo questions [Re: 4Play] #769509 12/04/06 12:48 PM
Canucklehead Offline
Thanks,
Ashby
1. You have some broken defroster elements. If your rear window is tinted you may be SOL. If not there is stuff that you essentially paint on over the broken section. You should be a ble to use a DMM to fins where the breaks are (unless you have tint over them).
2. Bad fuel level sending unit. Very common in 2nd Gen Rodeos.
3. Sounds like a bad fan clutch.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Couple of 2nd Gen Rodeo questions [Re: Canucklehead] #769510 12/04/06 06:43 PM
4
4Play Offline OP
That all sounds like it could be the issues.
1. My windows are tinted. What now?
2. Any way to test for that?
3. There are two fans one large one after the radiator and a smaller on before positioned to the left side. Where is the fan clutch and which fan would it effect?
Thanks alot!
Ashby
Re: Couple of 2nd Gen Rodeo questions [Re: 4Play] #769511 12/04/06 09:37 PM
HondaOfJustice Offline
hey i got 2 cents for ya, for checking the defroster. its tedious but use a razor blade to cut the tint off just over the elements and peal off the little strip so you can expose the elements and test them, and the fans .. the big one behind the radiator is your main fan for the radiator the smaller one in front of the radiator is for your AC system, im not sure how the dohc is but on the sohc when your timming belt starts to stretch or your tentioner gets week, the water pump starts to slip and not work, or if you got any oil on that belt some how it will slip on the water pump, something to check, when its overheating, is the heater still blowing hot air? if its not then your coolant isnt moving through the radiator or the heater core and your water pump isnt working for what ever reason
97 Honda Of Justice
calmini 3 inch lift shackles, cranked torsion bars
235/85/R16s eldorado trailcutter M/Ts
shopping for a locker
Re: Couple of 2nd Gen Rodeo questions [Re: HondaOfJustice] #769512 12/04/06 10:44 PM
Bigpoppax2 Offline
I'd say your tint shop needs to fix your defroster for you. I'm guessing yours did the same thing mine did. I just didn't realize it till winter time and didn't put 2 and 2 together for quite some time.
I took it back and they were more than happy to fix it for me.
Joe
Re: Couple of 2nd Gen Rodeo questions [Re: Bigpoppax2] #769513 12/05/06 12:32 AM
4
4Play Offline OP
Joe
Its been tinted for 5 years now and the problem only recently started. It could be a result of the tint, but since its worked so long, I don't feel right asking them to fix it.
Thanks.
Re: Couple of 2nd Gen Rodeo questions [Re: 4Play] #769514 12/05/06 01:35 AM
Gizzy42 Offline
You can take it to them to have them remove the existing tint, then fix it yourself, then take it back to have it retinted. Or have them fix it when they take the tint off.
Dont know how much that would cost but shouldnt be too much.
I had 5 lines out on mine before I had it tinted and fixed them before taking it in. For some reason one didnt get fixed right and still didnt work. Just in the last week or so I noticed another one isnt working. Not bad enough for me to redo the tint yet though.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Couple of 2nd Gen Rodeo questions [Re: 4Play] #769515 12/05/06 03:21 AM
4
4Play Offline OP
Okay.. Looks like Im going to head over to a local tint shop since I've moved away from where I had it originally tinted.
Anyone have an idea of how much it costs to fix defroster lines?
-Ashby
Re: Couple of 2nd Gen Rodeo questions [Re: 4Play] #769516 12/06/06 04:59 AM
rodeoredd Offline
dude you can totally fix this yourself <img src="/forums/images/graemlins/wink.gif" alt="" />
my tint has been bashed all to hell from the inside and still looks great from the out.
if you make little slits that are cut alongside the broken section of the defroster it will never show up...
find the broken spots by looking ay and following each line on the window and go buy the $5 fix it kit and go at it.
it may actually be quite therapeutic! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'99 Rodeo V6 4x4 w/ 8" lift, 33" TrXus MT
4.77, Aussie Locked rear, 8500lb winch, custom rack, custom winch bumper, ProComp lights, 230,000km
http://www.cardomain.com/ride/2231794
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6288 MB (Peak: 0.7353 MB) Data Comp: Off Server Time: 2026-07-13 18:20:58 UTC
