95 Rodeo clutch and slave cyl issues (again) #769587 12/04/06 09:01 PM
toowacky Offline OP
Hi all, I don't usually post here (normally in the Toyota forum), but my wife's got a Rodeo, and I'm looking for a few ideas on the issues I'm having to deal with... Kinda long, sorry.
1995 Rodeo 5spd 3.2V6
I replaced the slave cylinder about ~5,000 miles ago (early spring). It was leaking and from the piston-- no warning, just one day the pedal went to the floor, and the reservoir was empty. Pulled the old one, definitely leaking from the slave piston. Replaced w/ a new unit, let the old fluid drain from the line, installed, bled the system. Working well since then, then about a month ago the fluid was low again (down to minimum). Pedal feel was still fine. Topped off and things were good. Except I think some fluid leaked into the bellhousing, as the clutch was a little grabby, but I just was hoping everything would be OK.
Until Saturday, wife was traveling home from the mtn, and clutch pedal was soft, and the fliud was a bit low. Yesterday I pulled the little inspection cover off on the bellhousing, and the paint on the cover itself was bubbling off and wet, so I'm thinking even before I pull it off that the slave is toast. Again. I bled the system w/ my Mighty Vac, and pedal feel is restored, but I'm thinking this is very short term.
History on this truck is:
-Bought used at ~45K from dealer, dealer replaced clutch at ~50K on her dime. Symptom this time was, sitting at an intersection, tried to shift into first, pedal goes to the floor, clutch won't disengage.
-Clutch/slave replaced at ~109K, same symptoms, independent repair shop. Wife says she got the parts from the mech, including the old disc, slave etc. This is all before we were together, so all 2nd hand info.
-Truck now has ~146k on it.
She's in grad school, we've got a mortgage on one income, so money's tight. The history of this Rodeo means that it's a sore subject with her, and as much as I'd like a different vehicle, we can't afford to replace it. It's a great road trip vehicle and is loaded w/ options, so it's comfortable, too. A new slave might buy some time, but probably won't fix the underlying issue. I thought that moisture in the line might have caused previous failures (corroded bore, etc.), and that's why I drained the line and then bled, bled, bled. I did a fair amount of searching on the board, and did see mention of possible moisture causing premature failure of the slave cylinder. The other thing I was pondering was the slave cylinder piston overextending (possibly due to worn clutch components?) but c'mon, at 50K? Each time?
Any other suggestions? Maybe the fork is bent, causing further piston movement? I've seen mention of clutch pedal adjustment-- could this affect the overall travel of the slave cylinder, like maybe each time the clutch and slave are replaced, it's not adjusted right and overextends and fails? My wife's has good manual transmission operation habits, so I don't think that's the case. I mean she did have many more miles on a single clutch on a Honda (>150k). But something is whack. She doesn't have far to drive, so I'd replace the slave to get us by for a while (even if the disc is a little contaminated), but I really want to know why it's failing this often.
Thanks,
Tom
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: 95 Rodeo clutch and slave cyl issues (again) [Re: toowacky] #769588 12/09/06 02:55 AM
toowacky Offline OP
Just an update....
I replaced the slave, as it should buy me some time.
Last time the slave was replaced, I let the fluid drain from the slave line so there was new fluid in the system. This time, I also purged the fluid from the damper-- cracked the bleeder and let it flush through there, so hopefully that might help. The fluid that came out of the damper was extremely dirty and milky looking, probably contaminated with water? Bled forever with the Mighty Vac after that.
Anyway, the Rodeo is back in action, and the clutch *seems* more buttery smooth in the pedal action... Read that thread on taking the damper out, very interesting idea, definitely makes the circuit simpler, although getting rid of the horizontal routing doesn't apply in this case.
Tom
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5923 MB (Peak: 0.6438 MB) Data Comp: Off Server Time: 2026-11-16 08:39:43 UTC
