89 1st Gen antenna removal question #769595 12/04/06 10:09 PM
RidingRoughshod Offline OP
Need to replace my power antenna on my 89 4runner. I've read where you remove the top nut from the ant then run it up till it pops out but all mine does is clicks. I've tried pulling on it but that does no good..any ideas...Thanks
Re: 89 1st Gen antenna removal question [Re: RidingRoughshod] #769596 12/05/06 03:15 AM
fourwd1 Offline
If you're replacing the mast you have to pull the unit and pull the cover off first (at least on an 84). You have to remove the nut on top and 1 screw under the fender to pull the motor unit.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 89 1st Gen antenna removal question [Re: fourwd1] #769597 12/05/06 12:09 PM
Thanks..I'll give that a try
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.5922 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-06-17 13:15:14 UTC
