99 amigo Abs problem #769712 12/05/06 02:28 AM
mtbiker8399 Offline OP
I bought my amigo a little over a year ago, and the abs light was on but went off often. when the light was on i could lock them up and when its off i couldn't, its still doing this. Whenever i take it out in the mudd to play the abs always seems to work for a week or so with no problems. i have searched around under there and found nothing, anyone have this problem or know how to fix it?I don't think the sensor is bad i have puit 35,00 miles on it since i have gotten it, that would have been warn out by then
Re: 99 amigo Abs problem [Re: mtbiker8399] #769713 12/05/06 04:09 PM
HCMP Offline
There was a recall for the ABS module on that vehicle. Do you know if it was addressed?
Check your fuse as well and make sure you're plugged in there. and that it isn't blown
Re: 99 amigo Abs problem [Re: mtbiker8399] #769714 12/09/06 03:59 PM
LetsRodeo Offline
Here's a link to a previous post on the topic..........
ABS Trouble shooting and Codes
If you want something done right do it yourself two or three times!
LetsRodeo
1999 Isuzu Rodeo LS 4WD
3" CPL, 3" BL
LT265/75 16 TOYO Open Country AT
ShrockWorks Rock Sliders
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.5925 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-11-03 17:13:57 UTC
