Ever wondered how Monty II and III Active Track system works. #769971 12/06/06 04:05 AM
Alex Kogan Offline OP
IÆve been thinking about it last night and drawn up couple diagrams. At least that's how I understand it.
In fact itÆs quite simple. System consists of 2 solenoids, check valve, vacuum reservoir, some hoses and actuator. Vacuum is supplied through suction from intake manifold and kept in check with check valve.
With properly functioning system there are only two modes:
2WD. When electricity is supplied to both solenoids. Right side of actuator is connected to negative pressure right side to barometric pressure. Actuator moves from right to left - free wheeling clutch is disengaged.
4WD. Turn power off and springs return valves to original position. Now left side is equalized with atmospheric pressure and right side is connected to vacuum. Whoosh and free-wheeling clutch is engaged. Even when engine is turned off itÆs still going to lock up. That why when you leave your truck in 4WD for some period there is no waiting time for it to kick in.
08 PowerWagon (stock!)
Re: Ever wondered how Monty II and III Active Track system works. [Re: Alex Kogan] #769972 12/06/06 05:19 AM
Charlie Belew Offline
So it's just "atmospheric pressure and vacuum"? What about viscous coupling? How does that fit into the Active Trac system?
Re: Ever wondered how Monty II and III Active Track system works. [Re: Alex Kogan] #769973 12/06/06 05:28 AM
OTEP Offline
The VC is what allows the Pajero/Montero to be driven on tarmac in four wheel drive much like most car-based cute-utes nowadays.
Re: Ever wondered how Monty II and III Active Track system works. [Re: OTEP] #769974 12/06/06 05:33 AM
I was referring to front axle disconnect system. I guess I should correct the title. VC adds limited slip function to center differential. It's two separate units. Differential allows to drive Monty in 4WD on hard surfaces and VC prevents problems when one of the wheels looses traction. Otherwise it would take only one wheel spinning to stop the progress without center diff locked.
Re: Ever wondered how Monty II and III Active Track system works. [Re: Charlie Belew] #769975 12/06/06 05:37 AM
Scottie2113 Offline
that coupling that you speak of takes place within the transfer case
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Ever wondered how Monty II and III Active Track system works. [Re: Scottie2113] #769976 12/06/06 06:28 AM
Of course. Part #30421 couples with center diff via tabs.
wondered how Monty II and III Front axle disconnect Active Track system works. [Re: Alex Kogan] #769977 12/07/06 04:50 AM
V
VA_95LS Offline
That's good stuff Alex. Every now and then its hard to move the lever to put the Montero in 4WD. I guess it's because it has been seldom used these last four years, no snow.
Let me ask you this. Does the front drive shaft spin when in 'Free Wheeling' Two wheel drive? Looking at the transfer case diagram I would guess yes?
Thanks !
1995 Montero LS (Owned since a pup)
1996 Dodge Ram 2500
1998 Jeep Wrangler 4.0
Re: wondered how Monty II and III Front axle disconnect Active Track system works. [Re: VA_95LS] #769978 12/07/06 06:05 AM
bretwalda Offline
Yes good stuff - I think I'm getting it
...So practically speaking - a case problem...
I have not yet put in a new lower butterfly plenum on my DOHC. I have it disconnected.
When I am on a flat stretch of freeway doing about 70-75 on a windless day, (slower speed in headwind) my 4wd lights will start flashing. If I let off the gas and then step on it again to maintain my original speed - the lights will go off. Only to come on again over a short period of time or if I put a slight bit more load on the engine.
My theory is I have a vaccuum leak from the bad plenum, and this is somehow affecting the system. But isn't there less vaccuum at higher RPM's? So would it be a bad check valve?
I dont understand what the resevoir is doing either <img src="/forums/images/graemlins/confused.gif" alt="" />
Yes, go buy a plenum...somebody spare me $400. <img src="/forums/images/graemlins/barf.gif" alt="" />
I'm not willing to spend money, I'd just like some free answers <img src="/forums/images/graemlins/smile.gif" alt="" />
concreteprinter.com
Re: wondered how Monty II and III Front axle disconnect Active Track system works. [Re: VA_95LS] #769979 12/07/06 08:26 AM
TDoes the front drive shaft spin when in 'Free Wheeling' Two wheel drive? Looking at the transfer case diagram I would guess yes?
No.
As to 4WD they actually recommend to engage it every now and then just so it's kept in working order. Say every month or so.
Re: wondered how Monty II and III Front axle disconnect Active Track system works. [Re: Alex Kogan] #769980 12/07/06 03:12 PM
icysyrup Offline
Yes you need to engage or cycle through all the modes reagularly so it dont stick. My buddy has a Gen 3-2001 model and he has had problems with the Diaphram stickin on the front diff and not wanting to engage. Just gives you and excuse to get out and go 4wheelin <img src="/forums/images/graemlins/wink.gif" alt="" />
Bret, I would think you need to go through and check you vacuum lines to the front for leaks as well as the diaphram to see that its workin... <img src="/forums/images/graemlins/smile.gif" alt="" />
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6461 MB (Peak: 0.7680 MB) Data Comp: Off Server Time: 2026-05-30 01:15:31 UTC
