2.6 pinging
#770077
12/06/06 03:41 PM
Got a 87 Dodge Raider and it pings in 3rd 4th and 5th only if you dont get on it and drive normal want to know if any one else has had this problem
paved roads a fine example of needless goverment spending 87 Dodge Raider
Re: 2.6 pinging
[Re: camoraider87]
#770078
12/06/06 05:10 PM
Loosing any coolant? Mine did that right before the head gasket went. Also a sign of a sticky vac or centrif advance in the dizzy. How is the power?
Re: 2.6 pinging
[Re: fasteddy]
#770079
12/06/06 05:53 PM
as said it could be the distributer.also you need to check your timing.it sjould be 7* btdc give or take 2*.if you are at 9 then back it off to 7 or if you are at 7 back it off to 5.at 9* my truck will ping but it is fine at 7.
Re: 2.6 pinging
[Re: camoraider87]
#770080
12/06/06 07:17 PM
Ck EGR system operation. Conner
Over the hill but still climbing. 88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: 2.6 pinging
[Re: fasteddy]
#770081
12/06/06 09:20 PM
not looseing any coolant head just been done not to long ago new o2 senser
Re: 2.6 pinging
[Re: conner]
#770082
12/06/06 09:22 PM
have not checked timeing or egr
Re: 2.6 pinging
[Re: camoraider87]
#770083
12/06/06 10:17 PM
You'll need to follow the advise above, but you should start running higher octane gas too. At about 75,000 miles, my NA engine started pinging exactly as yours is. I checked timing and replaced dist. cap, rotor, plugs and wires to no avail.
Finally, someone suggested I fill-up with 93 octane gas. Never pinged a ping after that unless I went back to 87.
87 Montero, bought new, by me - 88/89 intercooled Starion Turbo engine- with awesome audio.
Re: 2.6 pinging
[Re: dadrab]
#770084
12/06/06 10:24 PM
I have a Ford Asspire lol, that also pings unless I use 93octane. I checked the timing but can't rely on that because someone may have changed the timing belt and was off a few teeth. As long as I use high test, it's fine. Better power too for a 1.3L. They may have advanced the timing for that reason. Little thing has no hp stock. I figure they squeezed out some more by advancing the timimg.
1987 Dodge Raider rebuilt Quest block bored .040 over put together, and installed by Shelby. 5spd, '87 stock turbo, Intercooled, 2.5" exhaust. MPI with hard pipes, FIP Pro-4, MSextra MS1
Re: 2.6 pinging
[Re: dadrab]
#770085
12/06/06 10:40 PM
I got new plugs, wires, dist.cap,rotor,to but ill try higher octane gas wont hurt nothing but my pocket <img src="/forums/images/graemlins/lol.gif" alt="" />
