igniter #770176 12/07/06 03:35 AM
jello Offline OP
can't find the right igniter 4 my 94
toyotatraxx
Re: igniter [Re: jello] #770177 12/07/06 03:49 AM
kewlynx Offline
Call the dealer with your VIN and have them look up the part number for you.
**ubi apis- ibi salus**
Re: igniter [Re: kewlynx] #770178 12/07/06 07:54 AM
dcg9381 Offline
bad news: It aint cheap.
How do you know it's the igniter?
22REturbo.net
1988 4Runner
Re: igniter [Re: dcg9381] #770179 12/07/06 08:37 AM
Z
zachtheterrible Offline
For as much as those stupid things are, just get an MSD ignition instead. Much better spark anyway. Unless you can find an igniter for real cheap
I got my 6A model on jegs.com for only 140 I think.
Make sure you know what it is first. Did you check your pickup coil and coil first?
Re: igniter [Re: dcg9381] #770180 12/07/06 06:55 PM
jello Offline OP
i have a igniter the plugs dont match.can i re wire the igniter?
check out my project
www.fattshack.com
larrys project
toyotatraxx
Re: igniter [Re: jello] #770181 12/07/06 07:22 PM
Staceman Offline
jello, this truck is beautiful!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
(just wanted to share)
Re: igniter [Re: Staceman] #770182 12/07/06 07:35 PM
jello Offline OP
the 85 is my budys truck
toyotatraxx
Re: igniter [Re: jello] #770183 12/07/06 07:47 PM
MAC Offline
i have a couple spares for my 87. i know that many years are interchangeable. if you find that you can use one from an 87 pm me.
Re: igniter [Re: zachtheterrible] #770184 12/07/06 08:28 PM
dcg9381 Offline
For as much as those stupid things are, just get an MSD ignition instead. Much better spark anyway. Unless you can find an igniter for real cheap.
At almost $400, it's worth chasing a used one.
It think the pickup in the distributor is more likely to fail.. It's a VR sensor, if I recall correctly and you can test it on the truck or by pulling the distributor.
You can't use an MSD in place of the ignitor on the EFI trucks.. The output of the ECU is square wave (4-5v) which has to be "translated" into when to fire the coil.
Carb'd trucks are different.
22REturbo.net
1988 4Runner
Re: igniter [Re: dcg9381] #770185 12/07/06 11:17 PM
jello Offline OP
is it posible to wire this direct without shorting it out.
i changed the truck from 2wd auto to 4wd 5 speed it had no igniter
toyotatraxx
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6353 MB (Peak: 0.7431 MB) Data Comp: Off Server Time: 2026-05-29 16:21:44 UTC
