valve oil seal or just the cap change time ?? (w/ pics) #770251 12/07/06 06:28 AM
dog1ph Offline OP
4G54 w/ auto tranny by the way
buddy of mine said oil seal change time other one said just the cap on valve cover- which one is it <img src="/forums/images/graemlins/confused.gif" alt="" />
could too much oil have caused this?
last time we put in 6 liters instead of 4.5-5 <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: dog1ph] #770252 12/07/06 06:56 AM
O
ojo1 Offline
From the photo's looks like just the cap, everything below the rocker cover look clean.
But really could be a damaged oil breather hose, there is normally one attached to the air filter box from the rocker cover (Or somewhere round there)
Doesn't look serious though.
Too much oil will cause leaks and seals to go (Messes with crank case pressure but thats what the breather hose to the inlet is for, releases pressure as well as lube the carb), but has it done this - probably not.
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: ojo1] #770253 12/07/06 12:58 PM
JAVYPRO Offline
I think that ojo1 nailed it, I suggest checking if the cap has the rubber seal at all, does it feel loose?
Oh my God, is that the factory radiator hose? looks like it...Nothing wrong, it amazes me that some of our rigs still wear factory parts, like I got the factory rear wiper blade that came with it, and the factory muffler, and the spare tire still intact, and and and, oh I was the first one to use the hyd. jack and lug nut wrench. The jack wasn't even scratched at the bottom but I got me another lug nut wrench to keep mine intact, might be worth something some day <img src="/forums/images/graemlins/smile.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: JAVYPRO] #770254 12/07/06 01:06 PM
FrankR Offline
Check the PCV valve to see if it's stuck closed.
Frank
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: FrankR] #770255 12/07/06 03:24 PM
icysyrup Offline
My vote as well is to start with the cap and go from there its a cheap replacement part and then see if that solves it...if not trace to PCV valve etc....
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: dog1ph] #770256 12/08/06 03:17 AM
dog1ph Offline OP
many thanks for the replies gents......
yup....still all factory
only way i know how to keep it...
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: dog1ph] #770257 12/08/06 01:19 PM
JAVYPRO Offline
Do you have a 2.6L on that? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
By the way it looks really good <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
me likey the rims a lot!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: JAVYPRO] #770258 12/09/06 05:43 AM
dog1ph Offline OP
yes sir....2.6L auto tranny, leaf springs, bouncy seats
from what i understand its a customized order for diplomatic corps in SE Asia
part of a set of pajeros with same body that came in blue, silver grey, red w/ black trim and one like mine
with a 2.6L or a 4D56- diesel engine manual or auto tranny
the rims are 18"ers from japan pajeros found only on this model
J-Top 2.5L TD (turbo diesel)
Re: valve oil seal or just the cap change time ?? (w/ pics) [Re: dog1ph] #770259 12/09/06 05:57 AM
stony-man Offline
Sweeet! Is that a tiny snorkel on the front fender? <img src="/forums/images/graemlins/lol.gif" alt="" /> What IS the purpose of a small mirror on the fender like that? I've driven a few sports cars with mirrors there, and it was extremely hard to see anything in them.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.004s) Memory: 0.6326 MB (Peak: 0.7387 MB) Data Comp: Off Server Time: 2026-06-07 03:19:27 UTC
