Re: changing 22re clutch question [Re: 10_35lookoutbelow] #770338 12/08/06 06:51 AM
OOP'S Offline
You are going to have the flywheel resurfaced?
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: changing 22re clutch question [Re: OOP'S] #770339 12/08/06 07:09 AM
4WD22R Offline
If not you'll have some more practice with takin' that clutch out here in a few months!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: changing 22re clutch question [Re: toyrunner] #770340 12/08/06 08:00 AM
rednekbean Offline
absolutly be very safe with this one i would use the strapes on the frame rail, or how i did this by my self in the driveway was took a screw driver across the floor board hole and looped two strap'es around the tranny transfercase and lower it from there aboout about 2' to a creaper so i could roll the tranny easier.
you can rent a tranny jack, or just lower the truck low enough to use the jack stands that you have available. i would recomend cleaning the tranny to so you can cheak for some leaks and the such.
regardless of how strong you think you are.
It would really leave a mark if that fell that far!
you aint kidding, back then i could bench 250 easy and i could barely lift the tranny combo off the creaper i had to slid it, its heavy, very heavy.
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: changing 22re clutch question [Re: OOP'S] #770341 12/08/06 04:33 PM
1
10_35lookoutbelow Offline OP
Gentlemen!
Thanks for the warnings about the transfer case and tranny weightàI will definitely be cautious, and keeping that baby near the ground! Good ideas for support though, I like the winch through the shifter boot idea, I have a come along but where could I anchor it in the cab?
OOPS to answer your question, NO the flywheel is not going to be resurfaced (I know, I know, if it was my baby I wouldà). My buddy is Po and canÆt even afford the clutch and more than a few hours without his truck getting him to work. I warned him!
Boys you should see this rig it looks like it came straight from Afghanistan minus bullet holes and a Kalashnikov. Definitely not a lifted, and locked trailer queen with glossy paint! But the Motor and drive trainàunfunkinbelieveable Toyota bomber! I love these types of rigs!! The kind of owner that hangs on to that dear baby hoping it will last yet another year to be safe for the road!!
Theresa the Toyota Terror-89 Toyota P/U (3.0L SR5, 5sp swapped in from auto, 3"B.L., 32X11.5X15 MT/R, 2.5" stainless magnaflow catback exhaust, leaky floor with cold draft @feet, FUBAR comptron now in glovebox)
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6113 MB (Peak: 0.6838 MB) Data Comp: Off Server Time: 2026-10-24 02:35:20 UTC
