Gen II front bumper removal
#770545
12/08/06 07:43 PM
Im usually pretty good at taking stuff apart, but this front bumper has me lost. Can some explain where to begin in getting this whole contraption off, I want to start from scratch and make my own. Thanks!
Re: Gen II front bumper removal
[Re: Robb]
#770546
12/08/06 07:50 PM
Take front skid plat off. Remove 4 bolt holding bumper to frame horns (2 each side). Remove bumper. <img src="/forums/images/graemlins/patriot.gif" alt="" />
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#770547
12/08/06 08:07 PM
Thank you sir! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Robb]
#770548
12/09/06 02:13 AM
yeah, the 4 bolts are kinda up underneath behind the bumper, long bolts like 5 or 6 inches long. the nuts are tig welded to bumper, if bolts are very rusty, it is possible to break the tig welds and be spinning the bolt for 30 minutes before you realize it aint comin out without holding that nut that I broke the tig welds off. that is what happened when i took mine off my SR
scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6014 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-06-23 21:15:15 UTCValid HTML 5 and Valid CSS
