Gen II aftermarket wheels #770549 12/08/06 08:16 PM
Robb Offline OP
I tried searching this a 100 different ways as im sure its been covered. I have 31x10.5x15 tires now on the stock wheels. The truck looks awfully tall and skinny. I want to some wider wheels im assuming 15x8, but im lost when it comes to backspacing and offset. I plan to upgrade to a 33in tires in the future and would like a wheel i can use with a bigger tire as well. My truck is the bottom of the line with no fender flares and I dont plan to go there. I do want the tire to stick out some. I plan to just get some cheap black wheels from summit or something. Offset/backspace suggestions needed! (maybe some pictures) Thank you!
-Robb
1992 Montero (pics)
www.HondaForeman.com
Re: Gen II aftermarket wheels [Re: Robb] #770550 12/08/06 08:50 PM
Mad_Scientist Offline
Hi Robb,
For reference there are a couple of pics of my maroon '97 LS with 32s here and here. The rims are 15x8 with 3.75" backspacing. The tires stick out a bit, which me likey. check it out and see if that's what you want. Good luck.
Re: Gen II aftermarket wheels [Re: Mad_Scientist] #770551 12/08/06 09:33 PM
Robb Offline OP
Thanks for the post, thats about exactly what I am looking for, is this the backspacing most people are running?
-Robb
1992 Montero (pics)
Re: Gen II aftermarket wheels [Re: Robb] #770552 12/08/06 09:46 PM
I think so, but I suspect there are all kinds of combinations running out there. Although I think ChrisJ said he was running 4"BS. His Raider is in the same thread. PM him to make sure.
Re: Gen II aftermarket wheels [Re: Mad_Scientist] #770553 12/08/06 10:19 PM
Robb Offline OP
OK, I think I am going to go with this wheel from Summit:
I only have the options of a 4 inch backspace and a 4.75 inch back space. How will the 4 inch backspace compare to your 3.75 inch back space, will this stick out farther, or sit in the wheel well more?
Here are the specs:
Rim Diameter (in): 15 in.
Rim Width (in): 8.00 in.
Backspacing (in): 4.000 in.
Offset (mm): -12.00mm
6 x 5.5 in bolt pattern
-Robb
1992 Montero (pics)
Re: Gen II aftermarket wheels [Re: Robb] #770554 12/08/06 10:56 PM
Oyaji_Jon Offline
That's the same wheel I'm running on my Gen I. It will be in the wheel well farther by 1/4". I think you'll like them, though because they'll stick out ~3/4" over stock.
HTH
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Gen II aftermarket wheels [Re: Oyaji_Jon] #770555 12/09/06 01:34 AM
torquemonster Offline
I have these wheels on my GenII 1991 JDM Pajero. they are Identical even down to the centre cap, and im sure they are way cheaper too. I have 16X8.
Re: Gen II aftermarket wheels [Re: torquemonster] #770556 12/09/06 01:53 AM
Robb Offline OP
Where did you get those? The wheels from summit are 36.99 each.
-Robb
1992 Montero (pics)
Re: Gen II aftermarket wheels [Re: Robb] #770557 12/09/06 06:09 AM
Unique is made by the same maker for Crager rims IIRC.
Re: Gen II aftermarket wheels [Re: off-roader] #770558 12/09/06 11:51 AM
well then that would explain why they are are the identical rim then haha.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6428 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-06-23 21:14:54 UTC
