Bent front crossmember #770734 12/09/06 02:51 AM
Ryan_Vazquez Offline OP
I have a 85 truck and the front crosmember is bent in a little bit. The front sheetmetal part is kind of puffed out and the back part is only slightly bent.
Has anyone replaced this crossmember with a square tube or similar. Does anyone know if a standard size tubing will work? Is it necessary to make a temporary crossmember to keep everything in alignment?
I have thought about using FRORF's frame brace, but i am not sure if it would really work because i would still have to fill the gap behind the plate and would be a bit of a hack job in my opinion. Although once done if it looks okay, I'll probably never think about it again
Thanks
Ryan
Re: Bent front crossmember [Re: Ryan_Vazquez] #770735 12/09/06 01:14 PM
missouriman Offline
picture would help
Re: Bent front crossmember [Re: Ryan_Vazquez] #770736 12/09/06 06:32 PM
eightyeight Offline
if you are talking about what i think your talking about, trailer hitch stock works nicely. cut to fit, weld it in. will be strong enough to use as a recovery point too.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Bent front crossmember [Re: Ryan_Vazquez] #770737 12/09/06 06:40 PM
abnormaltoy Offline
Somink like dis?
Front
Rear
Yes, I would weld in a temp crossmember before cutting.
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
Re: Bent front crossmember [Re: abnormaltoy] #770738 12/10/06 01:00 AM
That first picture is kind of what i had thought, except not as big.
The idea of using trailer hitch stock is what i had in mind. Is it the inside or outside part that fits?
Re: Bent front crossmember [Re: Ryan_Vazquez] #770739 12/10/06 01:38 AM
abnormaltoy Offline
Mine are 3x5 1/4 wall. It fit pretty well, not too much trimming. I had a friend machine the receivers, I pressed them in and welded them.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6102 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-11-02 19:38:34 UTC
