distributor timing? #771128 12/10/06 10:19 PM
1
1986xtracab Offline OP
I am in the process of puttung my truck back together and as I go to put my distributor back in I just noticed that the mark I put on the head is gone... I am correct thinking the rotor should be pointing to #1?
1986 xtra-cab 22re
stock everything
1991 bed
Re: distributor timing? [Re: 1986xtracab] #771129 12/10/06 10:34 PM
N
NE89Runner Offline
only after you find top dead center on the #1 cylinder
Re: distributor timing? [Re: 1986xtracab] #771130 12/10/06 11:35 PM
Jeffstoyo Offline
TDC of the firing stroke..The piston is at TDC twice with the #1 spark plug removed, put your finger over the hole as you turn the motor over and when you feel the air being pushed out you are at TDC on the firing stroke. You could remove the valve cover also and check for clearance with the #1 rocker arms to see.
Good luck
Jeff S.
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: distributor timing? [Re: Jeffstoyo] #771131 12/11/06 05:08 AM
4WD22R Offline
Good luck
Jeff S.
+1 alternatively, if you ain't got someone to help you, stuff a small piece of paper towel in the #1 spark plug hole, turn the motor over just a little at a time until the paper towel pops out, then line up the timing mark on the crank with the 0* mark. She should fire right up if you stab the distro in on #1, then throw the timing light on smile
Good luck <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6004 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-06-09 23:39:42 UTC
