Gen 3 Question #771215 12/11/06 02:19 AM
Seif1 Offline OP
Guys, have any of you played with disconnecting the sway bars for more articulation?
I went out today with my Nephew (2000 XJ) and I realize the Monty will never be able to articulate like the live axle Cherokee, but I'm wondering if anyone has any experience...
Thanks,
Mark
2003 Jeep Grand Cherokee
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
285/75/16 Dueler AT's
ARB air locker (front)
Custom Roof Rack
Re: Gen 3 Question [Re: Seif1] #771216 12/11/06 03:24 AM
Alex Kogan Offline
I believe icysyrup has his rear one removed. It would certainly improve articulation which actually not all that bad if you compare absolute values. At least on stock vehicles. Live axles is certainly easier to modify.
08 PowerWagon (stock!)
Re: Gen 3 Question [Re: Alex Kogan] #771217 12/11/06 04:05 AM
icysyrup Offline
Yup def helps to have front and rear swaybars off....every little bit you can gain helps with IFS/IRS.....i noticed a def difference on the same obstacle with them off it was much easier....Plus onroad driving isnt that bad...now that its wintertime I am putting the front back on, it will come back off in the spring...and the rear is gonna stay off indefinately... <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Gen 3 Question [Re: icysyrup] #771218 12/11/06 04:10 AM
Seif1 Offline OP
Cool, thanks.
Did you completely remove the bars are just "disconnect" them.
If you left them in place how did you hold the bar(s) up out of harms way?
Re: Gen 3 Question [Re: Seif1] #771219 12/11/06 04:18 AM
icysyrup Offline
Its pretty easy to just take em all the way off...not hard at all. The way the susp is set up i thought it would be harder to find a way to keep them tied up than to just remove 4 easy bolts and take em off...
Re: Gen 3 Question [Re: icysyrup] #771220 12/11/06 04:34 AM
Seif1 Offline OP
Thanks...
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
Custom Roof Rack
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6081 MB (Peak: 0.6783 MB) Data Comp: Off Server Time: 2026-06-23 18:45:27 UTC
