brake rotor #771397 12/11/06 08:00 PM
O
osirus Offline OP
The brake rotor on the front right hand side of my 2001 kia sportage will not come off. I think i've done everything I needed to do, but i would suppose it would have come off by now. I sat outside last night for maybe an hour with a rubber mallet trying to see if it just needed to be knocked loose; no luck. Any help would be greatly appreciated.
Eddie.
Re: brake rotor [Re: osirus] #771398 12/12/06 02:41 AM
V
victwisted Offline
Need more intell,I just had mine off tonight and regreased my bearings.They stick alittle to the spindle but with a mallet and a small bar it should slide off,that is if a 99 is the same as a 01,and you took out the two scerws holding the locking ring on <img src="/forums/images/graemlins/cyclops.gif" alt="" />
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
Re: brake rotor [Re: victwisted] #771399 12/12/06 06:17 AM
logansportage Offline
On the 4WD versions you don't have to take the 2 locking screws off. All you have to do is take the tire off, remove the caliper and the caliper mounting bracket. Then use a rubber mallet and hit the rotor from the back side at 12:00, 6:00, then 3:00 and 9:00. Do this a number of times increasing the amount of force on each full rotation.
The rotors can get rusted on and can some times require a lot of force and some penetrating lubricant like PB Blaster. (Make sure to take them to a shop to be ômeasured for thicknessö and "turned". Then thoroughly clean them with break cleaner when you install them)
I've found it useful to have something exactly opposite where the rubber mallet is hitting to keep the steering from moving.
Don't get mad and hit the rotor hard enough to warp it though.
Re: brake rotor [Re: logansportage] #771400 12/12/06 08:17 AM
Axe Man Offline
Kia Moderator Emeritus
Not true, unless someone didn't install the screws the last time the brakes were serviced. And at minimum you need a #3 phillips head to get them out. A #2 isn't large enough.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: brake rotor [Re: Axe Man] #771401 12/12/06 12:24 PM
O
osirus Offline OP
I broke a #3 head when I got one of the screws off actually. So, those DO go back on right? I do hope that damn thing comes off soon though. I need groceries <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: brake rotor [Re: osirus] #771402 12/12/06 09:17 PM
Cen_Tex_KIA Offline
Mine we're rusted, ended up drilling one out to get the rotor off. Didn't replace it. Hopin I didn't commit a foul. <img src="/forums/images/graemlins/shiner.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Re: brake rotor [Re: Cen_Tex_KIA] #771403 12/12/06 11:39 PM
V
victwisted Offline
BY taking the hole hub off it will make it easier to deal with the 3 screws holding the rotor on if they won't come off.If theres nothing holding the bearings on that are in the hub to the spindle other then the break <img src="/forums/images/graemlins/scared.gif" alt="" /> then yes it will come off,and mostlikely when your going to the store <img src="/forums/images/graemlins/zombie.gif" alt="" />Good luck doin 60mph <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: brake rotor [Re: victwisted] #771404 12/13/06 07:48 PM
Cen_Tex_KIA Offline
No, No, I was referring to the screws in the rotor <img src="/forums/images/graemlins/scared.gif" alt="" />........bearings are a slightly necessary to be locked down....if you want to keep teh shiny side up <img src="/forums/images/graemlins/shiner.gif" alt="" />!
Re: brake rotor [Re: Cen_Tex_KIA] #771405 12/13/06 08:21 PM
O
osirus Offline OP
Did I take everythingI needed off?
Re: brake rotor [Re: osirus] #771406 12/13/06 09:54 PM
A
Airdale73013 Offline
It looks as if you are ready to remobe the rotor. You may want to install the screws or a couble of bolts in the two theaded holes in the rotor and use those to help press off the rotor.
2009 Sorento LX, 4x4, V6, Auto, Red
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6424 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-17 06:37:12 UTC
