what engines will bolt to my tranny #771423 12/11/06 08:20 PM
rvdjr Offline OP
i might be in the market for a new engine for my jeep. if i do replace the engine i would at least like to explore the possibility of upgrading to a v8. does anyone know what engines will bolt up to my 904 automatic tranny?
thanks
Re: what engines will bolt to my tranny [Re: rvdjr] #771424 12/12/06 07:53 PM
JeePete Offline
IF it has the 258 bolt pattern the usual AMC engines will fit. 304 or 360 V8s among others (I doubt if you want bigger than a 360 but they're out there). A 360 Chrysler Jeep engine will not fit. Chrysler did use the AMC 360 blocks for a while though I know the 91 Grand Wagoneer still used the AMC 360. Not that it matters but the AMC 4 cyls use a GM bolt pattern and won't fit. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: what engines will bolt to my tranny [Re: JeePete] #771425 12/12/06 09:19 PM
rvdjr Offline OP
so it take it that any amc v8 will work but not a chrysler? and yes it has a 258.
Re: what engines will bolt to my tranny [Re: rvdjr] #771426 12/13/06 01:47 AM
BobRowe Offline
My CJ7 has an AMC 360 V8 bolted to the TF999 tranny - not stock, but works good. D300 T-case on the other end.
Re: what engines will bolt to my tranny [Re: BobRowe] #771427 12/13/06 05:32 AM
O
oldgreen Offline
I just swapped in a 304 into my 84 CJ7 in place of the 258. A couple of things you will need will be specific V8 motor mounts and buy a flexplate for a V8. I believe you can use the same plate for both the 304 and 360. 258,s are neutral balanced and the AMC V8,s are externally balanced by the flexplate. Also the V8,s generate more heat so you might want to get a 3 core or better rad.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: what engines will bolt to my tranny [Re: JeePete] #771428 12/13/06 06:02 AM
will a ford 302 fit? i was told it would, but i dont know.
Re: what engines will bolt to my tranny #771429 12/13/06 04:02 PM
BigJim Offline
Yes it will fit under the hood.. BUT you will need to fabricate mounts and an adapter plate from ADVANCE ADAPTERS.
The AMC engines would be far easier to install.
Re: what engines will bolt to my tranny [Re: BigJim] #771430 12/14/06 07:05 AM
RichieRich Offline
hey I have the original AMC 360 out of my 1976 J-10.
that would be nice
07 Mercedes GL 450
93 Freightliner FL 70 C/C 8.3 cummins, allison auto
96 Toyota T100 4x4 xtra cab v6 5 spd
05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r
04 polaris 500 HO 50th year limited
02 polaris 500 HO
51 willys M38
56 Dj
Re: what engines will bolt to my tranny [Re: RichieRich] #771431 12/15/06 01:14 AM
rvdjr Offline OP
do you have all of the brackets and accessories? if so, how much $ and where are you at?
Re: what engines will bolt to my tranny [Re: rvdjr] #771432 12/15/06 01:17 AM
rvdjr Offline OP
i just looked at your profile. if youre still in AZ shipping would probably knock me out of a deal unless youre giving it away.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6293 MB (Peak: 0.7191 MB) Data Comp: Off Server Time: 2026-11-02 19:38:46 UTC
