re-torquing head bolts #771609 12/12/06 08:18 PM
1
1986xtracab Offline OP
I havent really ran my truck since i got it all buttoned up but i couldn't remember when to re-torque the head bolts, was it after you let it get to operating temp and then do it hot?
1986 xtra-cab 22re
stock everything
1991 bed
Re: re-torquing head bolts [Re: 1986xtracab] #771610 12/12/06 08:51 PM
ChrisH Offline
Esquire812:
*You're safest bet is to follow the maufacturers guidlines. For example FELPRO puts no re-torqueing required in big letters on their packaging, while Engnbldr suggests its done with his graphite headgasket. I do it myself...right after I get the engine up to operating temperature and just prior to re-adjusting the valves after a top end rebuild. Then do a double check at the first oil change and have yet to have a gasket related failure since doing it this way. Just follow the torque sequence that you used when re-installing the head, and that all bolts are evenly torqued.
darin's smart <img src="/forums/images/graemlins/cyclops.gif" alt="" />
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: re-torquing head bolts [Re: ChrisH] #771611 12/12/06 08:59 PM
1
awesome, i just put the EB gasket on mine, so later tonight thats what I will be doing, that is after I assumne the position for exxon...haha
1986 xtra-cab 22re
stock everything
1991 bed
Re: re-torquing head bolts [Re: 1986xtracab] #771612 12/12/06 09:05 PM
TexJeff87 Offline
You definitely should. I found out the hard way...You gotta have the cover off to do the valves anyhow.
If Mad Max had a 4runner...
Re: re-torquing head bolts [Re: ChrisH] #771613 12/12/06 09:11 PM
mosk Offline
Do NOT re-torque a hot (or even warm) head, unless you like your head cracked.
The procedure I use is to fully warm the motor up to operating temp, to the point where the T-stat opens, and then beyond that until it reaches standard operating temp. Then shut it off and allow it to cool *completely*, like overnight. Once it is COMPLETELY COLD TO THE TOUCH, re-torque the head bolts/studs in order, to the proper spec. I have also heard the recommendation to very slightly increase the load on re-torque by 1-2 ft. lbs. so you are sure you are getting enough "bite".
Do this again after 500 miles, and you should be good to go for a long time.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: re-torquing head bolts [Re: 1986xtracab] #771614 12/12/06 09:58 PM
ChrisH Offline
...after I assumne the position for exxon
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
and just to re-iterate DONT TORQUE YOUR HEADBOLTS WARM
lol thanks mosk
Re: re-torquing head bolts [Re: mosk] #771615 12/12/06 09:58 PM
TexJeff87 Offline
OK, you got me there, Jeff...I failed to mention letting it cool first.
Re: re-torquing head bolts [Re: 1986xtracab] #771616 12/13/06 01:53 AM
BennyBoy Offline
Do your follow up when the engine is stone cold! as in over night. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: re-torquing head bolts [Re: BennyBoy] #771617 12/13/06 03:37 AM
1
well the truck will be sitting untill about 1pm tomorrow and then i'll be out of school and have time to re-torque.
1986 xtra-cab 22re
stock everything
1991 bed
Re: re-torquing head bolts [Re: 1986xtracab] #771618 12/13/06 11:16 PM
V
Volcom Offline
Is it necessary to torque the head bolts after 500 miles of a rebuild? Just curious?
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6349 MB (Peak: 0.7587 MB) Data Comp: Off Server Time: 2026-11-16 08:54:14 UTC
