Rims and Tires...question #771847 12/13/06 05:29 PM
uzombie Offline OP
I've 15x8 rims with 33's and the tires are now needing replacement (not due to wear but that the lugs are LOUDER now due to age?). I even have a new, unused spare (BTW, these are Bridgestone Dueler M/T Uni-T tires).
I would like to know what spec's I need for 16x8 rims so I can go to 285s. I've seen rims like Amer. Racing but none listed for Toyota (I see GM 6 lug 5.5 ctr) with 4.5" back spacing. None of the wheel sites list the T100 (1995) unless I put in 1998 T100.
I want black rims (prefer steel but alloys will have better unsprung weight) and A/T tires now (I'm doing more highway and the noise is bad. Even with the stereo up) <img src="/forums/images/graemlins/baby.gif" alt="" />
Thanks for any tips/help/suggestions!
Wheel Offset? (0, 12, 20) are these ok?
Bolt Pattern? 6x5.5 correct?
Mr. SuperPicky--
Re: Rims and Tires...question [Re: uzombie] #771848 12/13/06 06:57 PM
wsquaredodie Offline
My 93 T 4by has 16 inch tundra wheels (2002) with 265's on them. They just barly clear the mud flaps under load in turns. Diameter thing. Not sure on offsets but do not think you can squeeze a 285 in without occasional rubbing even if the flaps are not there. Check the FAQ's for more input. Seen some there.
trafdlo
Re: Rims and Tires...question [Re: uzombie] #771849 12/13/06 07:08 PM
Creeper Offline
Wow, Uzombie - longtime no see!
You can go with Tundra wheel offerings for a T100
- 6 on 5x5 is correct
- 3.75" or 4.5" backspacing
Here's a link for some nice aluminum black wheels I've been eyeballing. They also offer black steel wheels.
I saw something the other day where a guy ordered new black rims (can't recall from who) and they sent him chrome lug nuts so he had to purchase some black lug nuts seperately. Might want to clarify that if you order black wheels.
Ready to sell your TJM yet?
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: Rims and Tires...question [Re: Creeper] #771850 12/13/06 07:19 PM
ErikB Offline
Toyota Moderator
I was going to buy the black alloys from Wheelers linked above for my '97 runner but I went with the polished ones instead. I wish I'd have gone with the black ones though. <img src="/forums/images/graemlins/drunk.gif" alt="" /> I'm running 285's also (Bridgestone AT Revo's- nice tires!).
Most of the 16" wheels have 4.5" backspacing, but those are 16x8 w/ 4" backspacking- perfect, IMHO. Also FWIW, those wheels are just the ProComp Extreme Alloys and they have the black ones custom powder coated.
http://home.4x4wire.com/erik
Re: Rims and Tires...question [Re: Creeper] #771851 12/13/06 07:32 PM
uzombie Offline OP
Hey All! Long time no see um is right! Still got her (181K miles) Still have the TJM (but yet to put on revised brackets and beefed winch support). And still waiting on a Warn 8000 that a friend "said" he'd sell me cheap. But likely won't.
I just had 3rd Timing belt/pulley/water pump replaced (pre-emptive). And did the recall relay rod plus tie rod ends and new ball joints (Wow, steering feels like it did in 1995!!!).
I've considered the AT Revos that Erik mentioned in 285s. BTW, I should have mentioned she is still lifted at 3-4".
I may add a rear truck box for storage (I sure could use it for jack, blocks, tug em and tree cutting gear...).
Nice rims. I was looking at the teflon American Racing rims 'Chamber' model but man...$174 ea. So those ProComps might be cheaper.
I've stayed in touch with Harliv (he's a Dad now) and for those that guessed, his T is gone for a Chevy Tahoe (mostly for his EMT needs). He says hi.
Re: Rims and Tires...question [Re: uzombie] #771852 12/13/06 11:42 PM
95T100 Offline
I splurged and went with the American Racing Chambers in the Teflon, 16x8 4.5" Offset. American Racing #3985-6838. Really like them except. They too came with chrome lug nuts, so had to buy black and you will need a VERY thinwall socket to get to the lug nuts. Also, as the lugnuts are conical seats and not the type on the OEM rims, rotating tires is a bit more work (have to hold the tire "up" to get the lug nut started on the stud). I'll double check the box for the spacing to make sure I got it right. They do not stick past the fenderwells more than 1/2". I think they look good.
1995 Toyota T100, Rhino Liner, SwayAway Torsion Bars, Bilestien Shocks, Brembo Rotors, Akebono Pads, SS Brakelines, Monroe Steering Stabilizer & TRD/Eaton LSD
Re: Rims and Tires...question [Re: uzombie] #771853 12/14/06 01:08 AM
santacruzT100 Offline
This is my setup, I've got a 95 T-100 with NO lift, just the sway a way torsion bars cranked alittle...My wheels are American Racing black Fuel wheels with BFG muds 285/75r16...the back spacing is 5 inches and there is very minor rubbing when completely stuffed and turned while offroading. I did flatten the pinch weld. [Linked Image] [Linked Image] [Linked Image]
White '95 T-100 dx 4wd. Auto.
3.4l v6 w/K&N air filter
285/75r16 BFG's Mud on 16x8 American Racing black Fuel wheels.
Sway-a-way torsion bars, soon to add rancho 9000x
Re: Rims and Tires...question [Re: uzombie] #771854 12/14/06 03:13 AM
CJMT100 Offline
33x10.5 or 33x12.5 is on your truck now?
Re: Rims and Tires...question [Re: CJMT100] #771855 12/20/06 09:21 PM
uzombie Offline OP
33x12.5 I believe the 285s will be a inch less wide, which I'm fine with and prefer. Too much float and the wide ruts on the highway from heavy trucks makes her wander.
I'm interested in the Bridgestone AT Revos (285R16). And the Americal Racing Teflon Chamber rims.
However, anyone recommend a discount dealer for Amer Racing Rims? Most of the online places (TireRack, 4Wparts,...) are pretty close to MSRP.
Cha-ching.
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.006s) Memory: 0.6302 MB (Peak: 0.7363 MB) Data Comp: Off Server Time: 2026-10-24 07:32:04 UTC
