snorkel #771945 12/13/06 10:38 PM
i have a 97 wrangler with the 2.5L. i want to put in an ARB safari snorkel, but it only shows for the 4.0L. is there any way to make it work for the 2.5? thanks.
Re: snorkel #771946 12/14/06 12:12 AM
BigJim Offline
I think I would be askint this to ARB! But if it will fit a 6 surely there would be a way to MAKE an adjustment ti fit a 4 banger. I betcha ARB has already done it.
Re: snorkel #771947 12/14/06 07:19 PM
zxkevinxz Offline
hardware store plumbing section sells all kinds of intakes and intake adapters. <img src="/forums/images/graemlins/kewl.gif" alt="" />
"Not all who wander are lost"
86 CJ7; 258,MC2100,30/300/44,2.5" susp. lift,31s
Re: snorkel #771948 12/18/06 02:05 AM
0
05rubi Offline
if the air box is in the same place then ya if not idont know.my rubi loves the snorkel <img src="/forums/images/graemlins/smile.gif" alt="" />
05 rubicon rustys 3 in susp and ther stuff
Re: snorkel #771949 12/20/06 04:15 AM
A similar question - can snorkels be made to fit a carburated engine?
Re: snorkel #771950 12/20/06 02:33 PM
zxkevinxz Offline
yes.
Re: snorkel [Re: zxkevinxz] #771951 12/22/06 12:45 AM
JWaldz Offline
ok, this has always been my question. what else besides a snorkel would you have to do to help your jeep be water-proof. I mean, snorkel is the main thing that helps not getting water in ur intake but there is more to it right??
'99 Toyota 4Runner Limited
RP Black Widow|8K HID Kit|265/75 Federal MT|Cobra NightWatch CB|Fosgate Sound
Re: snorkel [Re: JWaldz] #771952 12/22/06 06:09 AM
BobRowe Offline
Well, you want to make sure your spark plug wires are fairly new and in good shape, and use dialectric grease on the spark plug fittings and the distributor fittings. You might consider putting liquid electrical tape or Krylon on some of the exposed electrical connections.
Nothing you do to that vehicle, spending only a reasonable amount of money, is going to make it into an amphibious vehicle. But if you take these precautions, you can dunk it in a stream for SHORT periods of time. Keep in mind that a lot of parts, like your alternator, can take in water and short out or at the very least corrode over time.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6134 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-10-21 17:40:19 UTC
