Spongy brakes #772024 12/14/06 06:08 AM
Rhino58 Offline OP
Have a 1993 Trooper thatall of a sudden the brake pedal seems spongy and doesn't stop well. Acts like the front brakes no longer work? Fluid level is still up and have done no work to brakes to permit air in system. I did hit the brakes hard while hunting but can't remember if the problem started then. Is it possible tohave "flipped" the cup in the master cyl. by braking hard? Any help would be greatly appreciated. Thanks! Gary
Re: Spongy brakes [Re: Rhino58] #772025 12/14/06 10:10 AM
52degrees Offline
Probably a stuck piston in the master cylinder. When's the last time you flushed your brake fluid? You should be doing it once a year or more if you play in the water with your truck. Air isn't the only thing that can get into your brake lines. Brake fluid readily absorbs water vapor right out of the air. This can cause your master cylinder parts to corrode and possible allow the piston to get stuck in the bore, which is what I believe may have happened here.
I wouldn't bother trying to fix a master cylinder. Just get a new one, bench bleed it very well and flush the rest of the old fluid from the system.
KG6VNX
Re: Spongy brakes [Re: Rhino58] #772026 12/14/06 06:17 PM
F
Fujisawa_Rob Offline
MC could be leaking internally. Definitely not worth rebuilding, especially since you can't hone an aluminum MC like you can with cast iron.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5914 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-24 11:56:46 UTC
