Question about starting........ #772690 12/16/06 09:16 PM
8
87YotaLac Offline OP
This question is not for a truck but for a car I have. I've got a 95 camry that won't start. When you try to start it, it does nothing. It acts like it doesn't have any power, the dash clock, radio, nothing gets power. I know its not the battery because I just put a new one in. But if you wait a while and try to start it again it will have power but won't turn over. After you turn the key the power goes off everything like the battery is dead. I figure there is probably a wiring problem of some kind. I bought it off a guy who tried to replace the engine but ended up with this problem. Decided to try to fix it sense he gave it to me for free! He said before he parked it, that it would start up and run but after it got warm if you turned it off it wouldn't start back. Any ideas on where to start?
1985 4runner Bone stock
Re: Question about starting........ [Re: 87YotaLac] #772691 12/16/06 09:36 PM
4Crawler Offline
Grab a volt meter and start testing voltages when it acts up and when it works fine. Start at the battery and work your way out from there trying to find where you see a big voltage drop at. Might be a loose connection or a power or ground cable that has corroded underneath the insulation at one end or the other.
Re: Question about starting........ [Re: 4Crawler] #772692 12/16/06 10:33 PM
DRTDEVL Offline
Me thinks bad battery cable...
Re: Question about starting........ [Re: DRTDEVL] #772693 12/16/06 11:48 PM
dogtoy Offline
Make sure battery posts are clean as well.
2014 FJ
Re: Question about starting........ [Re: dogtoy] #772694 12/17/06 12:49 AM
Z
zachtheterrible Offline
It could very likely be corroded/dirty battery posts. Sometimes my chevy s10 will not start, and you wait a few seconds, turn the key on n off and it'll start, I'm just too lazy to clean the battery <img src="/forums/images/graemlins/smile.gif" alt="" />
Is the starter getting any voltage when you try and start?
Do the radio and dashlights come on when you put the key into the start position but don't try and start it? or is that intermitent?
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Question about starting........ [Re: 87YotaLac] #772695 12/17/06 01:00 AM
casper3t Offline
I worked on a 90 camry and it had the same problem, we've tried replacing the starter, the starter relay, and new battery too, that didn't help. I read online somewhere that someone replaced the wiring harness to it and it worked fine after that. We never figured out the problem because we sold the car.
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.6113 MB (Peak: 0.6814 MB) Data Comp: Off Server Time: 2026-07-15 15:42:16 UTC
