Trouble code ?
#772696
12/16/06 09:43 PM
I finished the 3.4 install in my Runner. On its first real highway test it went into what appears to be safe mode.
The cel is on
Pulled trouble codes
P0100 P0101 P0102 P0110 P0141
The first four codes look to be pointing to a failed MAF. The reason I believe this is because for P0101 the MAF is the only trouble spot listed. The MAF is also listed as a possible trouble spot on the other codes. This MAF is a salvage yard part. Any ideas?
The P0141 is the NO. 2 heated O2 sensor. I extended the wires to this plug by soldering in wire. Does anyone know if changing the length of these wires will mess up the reading.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4 1995 4Runner V6 Auto 2WD
Re: Trouble code ?
[Re: Kutter]
#772697
12/19/06 07:09 PM
Follow up on the previous problem post.
Replaced the MAF and all trouble codes including the O2 sensor code cleared and it runs good. Actually it runs great. Even with the bad MAF it ran better than the 3.0 that was in there before. There are even a few new black marks on the road just for fun. The 3.0 took all it had to make a 2-3 foot peel out then it would almost die and stall. I left about 15 feet of rubber from my 31" Bridgestones and it was ready for second without stalling.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5881 MB (Peak: 0.6363 MB) Data Comp: Off Server Time: 2026-06-10 01:23:12 UTCValid HTML 5 and Valid CSS
