How fast have you R &R'd a 20/22R? #772900 12/17/06 02:59 PM
Stevie Offline OP
Here's my prob: Got an '80 4X4 that someone put an '85 22R in. It's got a oil/water mix problem, bad compression, unknown milage, and Lord knows what else wrong <img src="/forums/images/graemlins/confused.gif" alt="" />.
I happen to have a rebuilt 20R I was going to sell. Decided to swap. I'll then know what I have for an engine, and the truck will be configured correctly.
Question: How many hours has it taken you to swap engines? I'll be workin by myself, and will probably have to remove the 33s to kneel it low enough for my jack/garage.
Thanks.
'80 4X4 Longbed
Re: How fast have you R &R'd a 20/22R? [Re: Stevie] #772901 12/17/06 05:18 PM
CJM Offline
couple hours in and out .. if everything is ready to go .
then you'll have to do some "fartin" around .. the 20R carb. (choke) is coolant activated , you'll have to do some plumbing . maybe .. 20R was stock in your truck , so who knows what they did on the 22r ???
83 Trekker SR5
NEW Trekker forum
Re: How fast have you R &R'd a 20/22R? [Re: CJM] #772902 12/17/06 10:03 PM
dewmtndew Offline
There isnt much to swapping those engines. The little stuff will take the longest.
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: How fast have you R &R'd a 20/22R? [Re: dewmtndew] #772903 12/17/06 11:10 PM
kyle-22r Offline
if the engine is ready to go, and i've got the right tools at my disposal, it's a saturday afternoon type of affair. what takes the longest(especially on a 22RE) is getting all the wiring and hoses routed. my 22R on the other hand is mostly self contained, hook up the fuel line, plug in the igniter and alternator and it's ready to run.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: How fast have you R &R'd a 20/22R? [Re: Stevie] #772904 12/18/06 02:51 AM
kewlynx Offline
Two days by myself; no air tools. Long block at the ready to move accrouterments.
Amen on the little stuff taking the longest.
**ubi apis- ibi salus**
Re: How fast have you R &R'd a 20/22R? [Re: Stevie] #772905 12/19/06 12:32 AM
Stevie Offline OP
Took me 4 hours to pull it. It's in bad shape. Clutch plate's got worn "fingertips", rusted, and missing a 12mm mounting bolt, but dry (no engine/tranny leaks-Big Deal <img src="/forums/images/graemlins/rolleyes.gif" alt="" />). Head/block joint looks all corroded, and it's only been 4 months since mounted <img src="/forums/images/graemlins/angry.gif" alt="" />! Gonna clean up the flywheel & get it turned tomorrow. Now to see what all 22R plumbing/accessories will swap and those that won't. I think the block's backplate will, along with the PS, alt, smog pump, fan w/pully, motor mounts & belt tensioner. Gonna need an 20R aircleaner, and hopefully the headder will fit.
Any other ideas/advice?
'80 4X4 Longbed
Re: How fast have you R &R'd a 20/22R? [Re: Stevie] #772906 12/20/06 01:49 PM
Stevie Offline OP
Before you remove your engine, which you are planning to break down, loosen the crank pulley bolt first! <img src="/forums/images/graemlins/ignore.gif" alt="" />
'80 4X4 Longbed
Re: How fast have you R &R'd a 20/22R? [Re: Stevie] #772907 12/21/06 03:25 AM
kewlynx Offline
x 2 MANY TIMES OVER. <img src="/forums/images/graemlins/cheers.gif" alt="" />
To add, if the engine is still operational, to drain the antifreeze and run some antifreeze flush thru there with the heater turned ON, so it descales the core and plumbing as well, THEN start tearing it down.
That way it's not going back together with fresh 'freeze in a gunked-up system.
Re: How fast have you R &R'd a 20/22R? [Re: kewlynx] #772908 12/21/06 03:35 AM
You guys/gal make me sick. I've got 3 days into mine and I have yet to get the head pulled <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: How fast have you R &R'd a 20/22R? #772909 12/21/06 05:11 AM
dcg9381 Offline
3 days? Seriously?
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6385 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-07-09 17:58:57 UTC
