'93 Trooper SOHC vs DOHC #772915 12/17/06 05:06 PM
Our '93 Trooper has a bad engine. I can not find a Japanese replacement other than the DOHC. Anyone swapped the SOHC with the DOHC - and can you tell us if there were any unanticipated technical problems with the swap? Also, anyone have a clean SOHC 3.2L? Source for a SOHC that you can "vouch for"?
Re: '93 Trooper SOHC vs DOHC #772916 12/18/06 01:14 AM
litnin Offline
Yes, you can use a early model DOHC, but you will have to use
the intake system from the SOHC engine.
That is what I have in my '95.. it's a DOHC with a SOHC intake
and it runs great. It's 190hp vs. 175 SOHC engine and it has
the low end torque that the DOHC doesn't normally have.
You will also have to use the ignition system, wiring harness,
and exhaust manifolds from your SOHC. The EGR is in a different place on the DOHC, so to mate it up with the SOHC, you have to use the SOHC exhaust manifolds.
You'll use the airbox and throttle cable from your existing
SOHC also.
Other than that, everything pretty much lines right up and
goes in without a hitch.
Here's a pic of my DOHC in my SOHC truck.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: '93 Trooper SOHC vs DOHC [Re: litnin] #772917 12/18/06 01:27 AM
Richard Saylor Offline
Too freaking clean! <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: '93 Trooper SOHC vs DOHC [Re: Richard Saylor] #772918 12/18/06 04:59 AM
9
94redrodeo Offline
Whats the torque on the dohc
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: '93 Trooper SOHC vs DOHC [Re: 94redrodeo] #772919 12/18/06 04:13 PM
BigSwede Offline
I don't recall the torque number, but the hp is 15 higher on the DOHC. (190 vs. 175)
Serenity now!
Re: '93 Trooper SOHC vs DOHC [Re: BigSwede] #772920 12/19/06 12:34 AM
HondaOfJustice Offline
would this idea work on a 97 rodeo/passport?
97 Honda Of Justice
calmini 3 inch lift shackles, cranked torsion bars
235/85/R16s eldorado trailcutter M/Ts
shopping for a locker
Re: '93 Trooper SOHC vs DOHC [Re: HondaOfJustice] #772921 12/19/06 04:23 AM
JLEMOND Offline
NOPE , WONT WORK ON THE 96-97 ENGS, CRANK TRIGGERING SYSTEM IS COMPLETELY DIFF, THIS ONE JUST HAPPENS TO BE A RELATIVILY EASY CONVERSION, JERRY
Re: '93 Trooper SOHC vs DOHC [Re: litnin] #772922 12/20/06 04:30 AM
Bucket Offline
Clean Rig, Bro! Looks GREAT! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Bucket
'02 Trooper: OME 3inch lift, 33x10.5x15 BFG Muds on Black Rockcrawlers, ARB BullBar, Calmini T-bars, Indy4X HD Tie Rods and HD Rear Links, FDM sliders, Aisin hubs.
Re: '93 Trooper SOHC vs DOHC [Re: litnin] #772923 12/20/06 08:00 AM
trooperbc Offline
litnin:
so where did your dohc engine come from?
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: '93 Trooper SOHC vs DOHC [Re: trooperbc] #772924 12/20/06 04:44 PM
BigSwede Offline
[so where did your dohc engine come from?
I'm guessing Japan... <img src="/forums/images/graemlins/pfft.gif" alt="" />
Serenity now!
PHP: 7.4.33 Page Time: 1.005s Queries: 16 (0.913s) Memory: 0.6396 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-10-24 08:20:01 UTC
