Page 2 of 4 1 2 3 4
Re: 2003 Montero lift kit? [Re: Alex Kogan] #773086 12/23/06 05:41 PM
Seif1 Offline
I know, these were too good of a deal to pass up when I needed tires...
Soon...
2003 Jeep Grand Cherokee
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
285/75/16 Dueler AT's
ARB air locker (front)
Custom Roof Rack
Re: 2003 Montero lift kit? [Re: eleblanc] #773087 12/24/06 09:50 PM
Lygriek Offline
Other then the OME 2", coils and shocks, is there anything else to lift my 2003 Montero LTD. (no sport) What tire size can i expect to be able to fit? with those fender flares i doubt i can put much bigger.
Also can any guru out there tell me if i have solid lock or limited slip in the rear? I doubt i have anykind of lock in the front, maybe limited? My Montero is Canadien.
Just reread your post because I had a question, and realized that you asked about lockers and such. All the 2003 Fullsize Montero's have a the Mitsubish whammy cool traction control system, electronically controlled. I have found that it works VERY WELL. I know that the 2002 and older older GEN 3's were available with the oprional limited slip in the rear, here in the US at least.
My question, did you install the lift yourself or have someone else do it. I have been planing on doing it myself. The rear looks fairly simple, it's the front that seems like trouble. Any insite you or anyone else can offer would great!
Happy Holidays!
Michael
Lygriek, aka Michael
2003 Montero XLS GEN III, 285/75R16 Pro Comp Xtreme MT's
Ironman Springs/KYB Shocks. Custom Rocker Protection and Bumper.
Re: 2003 Montero lift kit? [Re: Lygriek] #773088 12/25/06 05:34 PM
Seif1 Offline
...My question, did you install the lift yourself or have someone else do it. I have been planing on doing it myself. The rear looks fairly simple, it's the front that seems like trouble. Any insite you or anyone else can offer would great!
Happy Holidays!
Michael
I had mine installed by a shop. both front and rear were a pain. I'm glad I did not tempt this in my garage...
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
Custom Roof Rack
Re: 2003 Montero lift kit? [Re: Seif1] #773089 12/25/06 06:00 PM
icysyrup Offline
It really isnt as bad as you think to do it. I started mine and was done in a half day. If you have a spring compressor and simple mechanical knowledge then it isnt that bad at all. Just have to unbolt the fronts and then compress them with the spring compressor and re-install in reverse order. The rears are even easier than the fronts cause the springs arent around the shock...so just compress the control arm and unbolt the shock then let out the arm slowly and re-install the spring and voila...done. Only thing you need to be carefull with is the spring compressor cause I have seen springs fly faster than you can see and that wouldnt feel too good if one came loose and hit ya <img src="/forums/images/graemlins/scared.gif" alt="" /> So just be carefull and take your time and its pretty simple...will save ya some dough <img src="/forums/images/graemlins/kewl.gif" alt="" />
There is a step by step write up on the web somewhere that I used the first time when I did mine and its on a 2001 that was a good detailed explanation....cant find it right now though cause I am not at my comp......I think Alex might chime in if he has it though for ya...or someone else <img src="/forums/images/graemlins/confused.gif" alt="" />
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: 2003 Montero lift kit? [Re: Lygriek] #773090 12/26/06 09:30 PM
E
eleblanc Offline OP
I had 285/75-16's on mine with the stock setup only had a little rubbing. I would think you could fit a little bigger, maybe.
Lygriek
Would you mine posting pictures?
And were was the rubbing? Rear, front, fenders, only when rear are fully turned?
Re: 2003 Montero lift kit? [Re: Alex Kogan] #773091 12/26/06 09:33 PM
E
eleblanc Offline OP
Nice to have more Gen 3s on board. I've got 285s with no lift on stock wheels. As far as rear you don't have either one just plain open diff but good traction control system.
I have a sticker on the side of the center console talking about center locking differentiel, so i would think i have but exactly what type and where, only rear? I'd like to find exact spec of my canadien verison of the truck but i haven't found anything. I may just email mitsubishi canada.
Re: 2003 Montero lift kit? [Re: Seif1] #773092 12/26/06 09:34 PM
E
eleblanc Offline OP
I just installed Ironman springs and KYB Gas-A-Just shocks on my Gen 3...Very happy with the lift thus far.
Rims are next...
Could you point me to ironman website? i can seem to find it.
Re: 2003 Montero lift kit? [Re: icysyrup] #773093 12/26/06 09:36 PM
E
eleblanc Offline OP
I have the OME lift on mine. The HD all around and I really like it. Does much better offroad with the springs and handles towing loads better too...no rear end sag. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'm thinking about because i think stock shock sucks, but i'm concern about going HD, is it much stiff then stock to a point being unpleasant?
Re: 2003 Montero lift kit? [Re: Lygriek] #773094 12/26/06 09:45 PM
E
eleblanc Offline OP
Lygriek
I seem to have bigger fender flares then the US version or the picture of the white one in this thread, here is a pic from my canadien version. You still think 285/75 would fit?
http://www.ericleblanc.com/gallery/...g2_itemId=2640&g2_serialNumber=2
http://www.ericleblanc.com/gallery/...g2_itemId=2644&g2_serialNumber=2
Re: 2003 Montero lift kit? [Re: Seif1] #773095 12/26/06 09:52 PM
E
eleblanc Offline OP
BTE your signature say 275/75R16 BFG AT, but that size doesn't seem to exist at least on there canadien site.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6416 MB (Peak: 0.7693 MB) Data Comp: Off Server Time: 2026-06-23 01:16:16 UTC
