04 Tacoma Warn Conversion Kit
#773346
12/18/06 09:05 PM
Can anyone suggest, or tell me if there is a manual hub conversion kit available for my 2.7 Tacoma?
Thanks!!
Re: 04 Tacoma Warn Conversion Kit
#773347
12/19/06 12:56 AM
My 04 Tacoma has the ADD setup, and according to a few artices, the manual hub bolt on is pretty simple. However, Im unable to find a set that matches the 04 year. I know if you want to lift the truck, a the outer portion of the shaft needs to be replaced with an expensive kit from Offroad Solutions, but all I'd like to do is free up the hubs for improved gas milage and less wear on the front drive. Does anyone have any suggestions?
Thanks!!
#773348
12/19/06 01:26 AM
Downey Off Road has a kit.
#773349
12/19/06 06:58 AM
Toyota Moderator
....all I'd like to do is free up the hubs for improved gas milage and less wear on the front drive. It is a Toyota and will last a good long time without this conversion....unless you have a 3" lift, that may cause some problems with the front axle boots. Mileage savings...not too likely, or not worth the price of a conversion.
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
PHP: 7.4.33 Page Time: 0.005s Queries: 14 (0.004s) Memory: 0.5916 MB (Peak: 0.6487 MB) Data Comp: Off Server Time: 2026-05-29 17:06:25 UTCValid HTML 5 and Valid CSS
