Mar-tacked axles #773350 12/18/06 09:55 PM
Squishy Offline OP
So I managed to find some used old style long-fields. When I assembled my solid front I was unaware the the axle shafts had to be mar-tacked so I just threw in new retainer clips. I was informed that they should be mar-tacked after I had finished the axle... D'oh! <img src="/forums/images/graemlins/confused.gif" alt="" /> The snap ring supposedly can break and get caught up in the bearings.
Pro's and Con's! I really don't want to disassemble my axle again, but I don't want to blow up a birf either. Any wisdom to be shared? Experience with this?
Justin Morgan-Speed never killed anyone, it's the sudden stop at the end that'll get ya
1988 Toyota 1/2 ton
Solid front axle, locked fore and aft, 35's and 5.29s.
Re: Mar-tacked axles [Re: Squishy] #773351 12/18/06 11:02 PM
Staceman Offline
If you've already got the snap ring in there, leave it and run it. Main reason for Mar-Tack is ease of replacing birfs/axle shafts on the trail. Then you don't need to deal with pulling the 2 apart, and getting the birf back on with that clip inside the birf.
I would tack them next time it's apart.
Re: Mar-tacked axles [Re: Staceman] #773352 12/19/06 04:43 PM
Squishy Offline OP
ya i'm just worried about the snap ring breaking if anyoine's even heard of that
1988 Toyota 1/2 ton
Re: Mar-tacked axles [Re: Squishy] #773353 12/19/06 07:33 PM
Staceman Offline
Personally, I haven't.
Re: Mar-tacked axles [Re: Staceman] #773354 12/20/06 09:36 AM
Brian894X4 Offline
Me either. I just used snaprings on mine instead of Martacking.
Re: Mar-tacked axles [Re: Brian894X4] #773355 12/20/06 01:12 PM
4x4runner Offline
I thought the reason to mar-tack, was to prevent the axle from walking into the carrier?
Re: Mar-tacked axles [Re: 4x4runner] #773356 12/20/06 01:27 PM
subliminaltrips Offline
x2 and ease of birf replacement
Re: Mar-tacked axles [Re: subliminaltrips] #773357 12/20/06 02:02 PM
TexJeff87 Offline
If Mad Max had a 4runner...
Re: Mar-tacked axles [Re: TexJeff87] #773358 12/20/06 02:44 PM
Red_Chili Offline
Toyota Section Staffer
I tacked, 88toy did not, both of us running Longfields (the old, welded variety). I thought I had heard that Bobby strongly recommended against using the clips instead of tacking, for reliability reasons?
Could be wrong, been so before.
-Bill
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6272 MB (Peak: 0.7139 MB) Data Comp: Off Server Time: 2026-11-02 15:16:19 UTC
