91 Corp. Axle/Rear end noise - "hooting" (not a whine) #773895 12/20/06 05:58 PM
marcucci Offline OP
Hi, I'm back from the dead.
The Trooper has 263,000 miles on it and is still going strong. For, oh, maybe the last 50k miles or so I've had this odd "hooting" noise coming from the back end. Sounds like the brakes but it's hard to tell. When I take a turn (sometimes) OR when I side-load the truck and roll it in the driveway, I get a sound that can only be described as an owl hooting. Lasts as long as the loading is present when it decides to do it.
The hubs seem solid in place (i.e. no lateral play) and a brake job seems to fix it for a short time (the 91 does have discs in rear). This is the OE corp axle with nothing more than a diff fluid change around 170k miles. No leaks.
Any ideas?
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: marcucci] #773896 12/20/06 06:19 PM
mlclark Offline
Isuzu Moderator
Todd-
You did not use OEM pads did you? <img src="/forums/images/graemlins/smile.gif" alt="" />
That is what has be affectionately referred to as the "Isuzu Mating Call" and is usually caused by using aftermarket pads, shims ect. Yes, a brake job will fix it for a while. Anti-squeal, anti-seize and all that goop will help for a bit, but in the end it always returns.
The good news is it is doing no damage, except for the embarrassment you feel driving through a parking lot.
Good Luck,
Michael
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: mlclark] #773897 12/20/06 06:24 PM
marcucci Offline OP
It's really that easy?
I honestly can't remember- they have been on there for a good 60k miles. I may just go get some OEM ones and replace them. OEM ones will fix them? Do they come with the shims, etc., or do I need to get those seperately?
Thanks!!!
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: marcucci] #773898 12/20/06 07:10 PM
Richard Saylor Offline
The last set I bought came with pads, shims, and the goop for between the pads and shims and the goop for the pins. That was for the front, but I assume the rear would be the same.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: Richard Saylor] #773899 12/20/06 09:00 PM
mlclark Offline
Isuzu Moderator
Yup, the OEM pad sets come with everything.
Michael
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: mlclark] #773900 12/20/06 09:48 PM
A
acy76 Offline
My old gasser '88 Troop does this, too, but only in reverse and only when cold. I kind of like it (always knew it was brakes) - not as cool as the bad front ball joints in terms of sound, though. Used to bray like a donkey when the two were in concert.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: marcucci] #773901 12/21/06 01:15 AM
88SuperTrooper Offline
LOL man I thought I was the only one who got that sound....All I can do Is live with it too as I just did brakes not too long ago. "Isuzu Mating Call" now thats funny
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: 88SuperTrooper] #773902 12/21/06 04:07 PM
thepcguy Offline
Mine is looking for a mate too. It's done it ever since my grandpa bought it in 1989-90. My truck, even with "oem" pads has still done it. I've just gotten used to it. At least with the noise I know there is still pad material left ::chuckle::.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: thepcguy] #773903 12/21/06 09:08 PM
JLEMOND Offline
THESE PADS ARE THE CORRECT , NON HOOTER CALLING ,IF INSTALLED WITH EVERYTHING NICE AND CLEAN THEY SHOULD BE GOOD FOR A LOOOOONG TIME 897049-4300 THESE ARE NON ASBESTOS,
THE STANDARD PAD 897018-3570 MAY OR MAY NOT GROAN A BIT DEPENDING ON THE SURFACE PREP OF THE ROTOR AND THE CALIPER GUIDES BEING NICE AND CLEAN AND LUBED CORRECTLY , THESE WILL LAST THE LONGEST BUT NEED MORE ATTENTION TO THE MAINTENANCE OF THE SMALL PARTS .. JERRY
Re: 91 Corp. Axle/Rear end noise - "hooting" (not a whine) [Re: JLEMOND] #773904 12/26/06 02:22 PM
marcucci Offline OP
Thanks, Jerry, and everyone else, for the help!!! I'll try the "better" pads and also do the full lube. I know I have a torn dust boot back there, but no problems with the braking systen other than the noise... yet. I'll see if I can get a new seal & do a bleed while I'm back there.
She just turned over 264,000 miles this morning! Those are the OEM rear calipers, never rebuilt...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6330 MB (Peak: 0.7407 MB) Data Comp: Off Server Time: 2026-06-22 06:13:20 UTC
