Useful carb info and part number
#774105
12/21/06 07:50 AM
Anyone who has worked on a 22R carburetor knows about the spacer that goes between the carb and the intake manifold.
From the factory the gaskets are attached to this spacer, so you wind up either having to stack the gaskets from the rebuild kit, or trying to file down the spacer and hoping it doesn't leak. Which it usually does.
I sort of automatically assumed the spacer would be about a million dollars from the dealer, but it turns out it's around 20 bucks.
21912-35050
The Napa gaskets don't have the holes for the PCV passages in the spacer anyway; the factory setup works far better.
I'd highly recommend it for anyone pulling their carb off to work on it.
Re: Useful carb info and part number
[Re: stock87]
#774106
12/21/06 07:56 AM
Thank you; I've got some carb-specific stuff in the p/n thread; will put it there. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: kewlynx]
#774107
12/22/06 01:04 AM
When I rebuilt mine the kit came with new gaskets for the spacer...not a new spacer but I just reused the original. Can't say if it's leaking, I rebuilt the thing about a year ago and it runs fine
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: stock87]
#774108
12/22/06 02:03 AM
thanks! just finished rebuilding my carb and I was trying to figure out why i couldnt scrape the old gasket off the spacer <img src="/forums/images/graemlins/smile.gif" alt="" />
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6021 MB (Peak: 0.6580 MB) Data Comp: Off Server Time: 2026-11-02 08:27:37 UTCValid HTML 5 and Valid CSS
