1979/1983 Speedo swap. #774109 12/21/06 08:53 AM
G
grub Offline OP
My old pickup has the bare bones speedo with no trip meter, has anyone done a swap like this for something nicer from say the SR5 with the tach ? I'm assuming the whole guage panel is a one piece unit, but I'm wondering does it matter if it comes from an auto or standard trans vehicle, mine is an auto, would the cable ends be the same ?
Re: 1979/1983 Speedo swap. [Re: grub] #774110 12/21/06 09:33 AM
kewlynx Offline
You might want to double check the fitment into the dash more than anything at this point. Yeah, the unit is one whole piece. If you pick up a donor cluster, see about taking the cable with; easier to change the cog on the tranny side, I'm thinkin'.
Unusual swap, but interesting nonetheless.
**ubi apis- ibi salus**
Re: 1979/1983 Speedo swap. [Re: kewlynx] #774111 12/22/06 07:12 AM
kyle-22r Offline
the speedometer cluster bolts in between 1979 and 1983, but the wire plugs changed a couple times so you'll have to do some splicing(get the plugs from the cluster that you're going to put in!). '79 used round plugs and i think '83 used square ones.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 1979/1983 Speedo swap. [Re: grub] #774112 12/24/06 06:49 AM
fourwd1 Offline
Yeah, the plugs are different between the years but the clusters are physically interchangeable. Grab the cable too, it may be a different length between auto and manual trannys (but probably not).
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 1979/1983 Speedo swap. [Re: fourwd1] #774113 03/20/07 10:30 AM
G
grub Offline OP
Great info everyone thanks a lot ! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-10 00:08:02 UTC
