Goodyear MTR tires wear unevenly #774149 12/21/06 09:44 PM
TCAO Offline OP
My front set of Goodyear MTR tires on my Tacoma is wearing out unevenly, one lug is higher than other. I had my truck aligned twice. People tell me that my coil over adjustable socks are going bad. I am thinking may be I have been cranking them so high that there is no room for the coils to compress freely. Any opinion would be appreciated.
Re: Goodyear MTR tires wear unevenly [Re: TCAO] #774150 12/21/06 09:56 PM
DentedTacoma Offline
If you crank them after an alignment that will mess the alignment again. It would think it would be alignment related or loose tie rod or something?
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Goodyear MTR tires wear unevenly [Re: TCAO] #774151 12/22/06 03:14 AM
kewlynx Offline
Check the ball joints too.
**ubi apis- ibi salus**
Re: Goodyear MTR tires wear unevenly [Re: TCAO] #774152 12/22/06 01:49 PM
ACES_HI Offline
If you havent done so yet have the tires re-balanced.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Goodyear MTR tires wear unevenly [Re: TCAO] #774153 12/22/06 03:48 PM
Mark in AZ Offline
Toyota Moderator
We've had problems here with shops not understanding how to get lifted Tacomas aligned. Next time ask for a print out showing the results so you can see that it's in spec.
Exploring in a T4R Ltd V8
Re: Goodyear MTR tires wear unevenly [Re: Mark in AZ] #774154 12/22/06 05:30 PM
azrain Offline
My 4Runner would feather edge the MT/R's after I knocked the alignment out of spec. I agree, sounds like an alignment issue.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6084 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-05-25 18:18:18 UTC
