PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6183 MB (Peak: 0.6931 MB) Data Comp: Off Server Time: 2026-06-07 10:14:35 UTC
, cost me less than $3. You could also go to a wrecking yard pull the A/C pulley and weld a bar to it, having a shop weld them together should be rather cheap, less than the $75 the bar costs through a parts store(if you can find them) You then bolt the bar to the crankshaft pulley, set the end of the bar against the frame and tighten the crankshaft bolt.
