95 Montero Compass/Outside Temp Gauge #774745 12/22/06 11:35 PM
danamr Offline OP
Is the back light replaceable in these units? I have it off the car, and it is not clear that the unit can be taken apart safely.
Re: 95 Montero Compass/Outside Temp Gauge [Re: danamr] #774746 12/23/06 12:02 AM
4xmonty Offline
Yes they are I believe there are two.They are tiny lights that you can get from Mitsu.It's been awhile since I replaced them it really easy. <img src="/forums/images/graemlins/scared.gif" alt="" />
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: 95 Montero Compass/Outside Temp Gauge [Re: danamr] #774747 12/23/06 06:37 AM
Scottie2113 Offline
once you take the compass unit out of the pod assembly, there are two holes at top one on each side. use flat tip screw driver to unscrew the light bulbs from back of unit. screw in new light bulbs from dealer. they are like 3 bucks each.
scottie
i just did mine. if you want to talk over phone, email me.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: 95 Montero Compass/Outside Temp Gauge [Re: Scottie2113] #774748 12/25/06 01:49 AM
danamr Offline OP
Two?
On my compass there is one small bulb at the 2:00 position looking at the front of the unit, then a more normal bulb that lights the Oil Pressure, and Amp guage. I don't see a 2ed bulb for the compass. I have taken the gauge set as apart as it will go.
Thanks for all the help.
Dana
Seattle
Re: 95 Montero Compass/Outside Temp Gauge [Re: danamr] #774749 12/25/06 04:26 AM
Scottie2113 Offline
well unless there are slightly different kinds of compasses, mine had two bulbs, one at the 2 o clock position and one at the 10 o clock position, both were identical.
scottie
Re: 95 Montero Compass/Outside Temp Gauge [Re: Scottie2113] #774750 12/25/06 07:15 AM
danamr Offline OP
scottie
It looks my rig is a couple of years older than yours, and I think the 95 was the first for the compass, so I am not surprised the compass is not very bright in my rig, I suspect they figured out they needed more light than one bulb gives.
Thanks for the help guys.
Dana
Re: 95 Montero Compass/Outside Temp Gauge [Re: danamr] #774751 12/26/06 04:04 AM
Robb Offline
I have a baseline 92 Montero, and it didnt orginally come with the extra set of gauges, so i bought some off ebay. Where the guauges go is just some thin plastic, i cut a hole there looking for a wire harness, but had no luck. I wouldve figured even the baseline would have the wiring, any tips on locating that harness, or what needs to be done to hook these up??
-Robb
1992 Montero (pics)
www.HondaForeman.com
Re: 95 Montero Compass/Outside Temp Gauge [Re: danamr] #774752 12/26/06 11:17 PM
Houston Offline
My '92 has one "inner" bulb for the compass, there are "outer" bulbs for the other gauges, maybe that's where some the confusion is coming from. You have to disassembly the unit much more to access the inner bulb that lights up the compass. I have a spare compass bulb at home,still in the Mitsubishi parts bag, I'll get the # and post it for you once I get home. I bought 2 when my bulb went out earlier this year, you never know when a part is going out of production
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: 95 Montero Compass/Outside Temp Gauge [Re: Houston] #774753 12/27/06 06:50 AM
stony-man Offline
Hey Robb. I did the same thing a few years ago. I ended up re-selling the cluster on Ebay after there were no wires to be found inside my dash. I still have the hole in my dash where thought I'd connect it. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 95 Montero Compass/Outside Temp Gauge [Re: stony-man] #774754 12/27/06 08:50 AM
LandRaider Offline
I bet the harness is there taped up into the rest of the wiring. Prob all it needs is power also??
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6388 MB (Peak: 0.7632 MB) Data Comp: Off Server Time: 2026-06-09 18:19:11 UTC
