Re: 95 Montero Compass/Outside Temp Gauge
[Re: LandRaider]
#774755
12/27/06 02:22 PM
It has to be in there somewhere, why would Mitsu have 2 diff wire harnesses???
[Re: Robb]
#774756
12/27/06 02:55 PM
It would not surprise me that there is more than one harness, I do allot of custom conversion work and routinely need to add circuits to get what I need.
[Re: Houston]
#774757
12/28/06 08:41 AM
My '92 has one "inner" bulb for the compass, there are "outer" bulbs for the other gauges, maybe that's where some the confusion is coming from. You have to disassembly the unit much more to access the inner bulb that lights up the compass. I have a spare compass bulb at home,still in the Mitsubishi parts bag, I'll get the # and post it for you once I get home. I bought 2 when my bulb went out earlier this year, you never know when a part is going out of production That sounds like the unit in my 95. From the description above, I think they added another bulb to the later models. Thanks for the offer for the bulb #.
[Re: danamr]
#774758
01/03/07 02:21 PM
The compass bulb is # MB898179-I checked with my parts guy at my local dealer that I buy from, as well as the extra bulb I have when I bought 2 bulbs last year, with one as a spare for the compass backlight. Built-in bulb holder, with a green sleeve over the bulb. The bulb/holder is of the "Twist out" style like on many other Montero bulb applications. Hope this helps you out
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting..... Stock & Happy otherwise
[Re: Houston]
#774759
01/05/07 05:17 AM
The compass bulb is # MB898179-I checked with my parts guy at my local dealer that I buy from, as well as the extra bulb I have when I bought 2 bulbs last year, with one as a spare for the compass backlight. Built-in bulb holder, with a green sleeve over the bulb. The bulb/holder is of the "Twist out" style like on many other Montero bulb applications. Hope this helps you out Thanks, that does.
[Re: danamr]
#774760
01/05/07 11:28 PM
Mine have been out since I bought it. I figured since it was an LCD display, it did'nt have lights. I'm happy to learn it not only has them, but they can indeed be replaced. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 Montero LS 24V DOHC 3.0L. 98 Montero 24v SOHC 3.5L, factory rear locker, Winter/tow package. 63 Jaguar XKE 3.8L FHC 2000 Mercedes-Benz e430 07 fj cruiser
