Engine Serial number Search #774808 12/23/06 04:21 AM
W
w4yn Offline OP
I have an engine I am trying to ID the serial number is 0555987. It came in to sick bay in an 86 2x, but it has dome pistons and single row chain so I suspect it may be an 84.
My 81 has double row chain and dome pistons, my 86 4runner had flat top and single row chain.
On a similar note can the 81 double row chain set up be used on later single row engine???
I assume the cover, guides atc will need to be changed.
Tim
old Toy Man
81,84,86 2wh drive 86 4runner 84 4x4 99 Taco
07 FJ
Re: Engine Serial number Search [Re: w4yn] #774809 12/23/06 08:30 AM
4WD22R Offline
Call your local dealer with the number, they should be able to tell you when it was made within a few months or so.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Engine Serial number Search [Re: w4yn] #774810 12/23/06 09:31 AM
kewlynx Offline
In my own experience, if the oil pan is off, there is a date stamped in the mating surface on the rearward side that is the casting date. Obviously it's not the 86's original mill. Keep in mind you also see these in the old Celica's; you just change the oil pan and dipstick (1" difference)
20R22R History
I think LC Engineering sells the TC kit you're asking about.
You WILL need a pre-85 timing chain; there's 3 links difference between them and later 22Rx's, due to the change in block/head heights. That's why you don't go mixing between the years to put together a long block.
**ubi apis- ibi salus**
Re: Engine Serial number Search [Re: 4WD22R] #774811 12/23/06 02:57 PM
W
w4yn Offline OP
Tnx for quick replys!
I will finish pulling engine today. It appears to be a 83-84 engine. Will verify later when pan is off.
#1 cylinder has some scrape marks like wrist pin may be loose.
Head had some corosion around exhaust valve water pockets(seems common)will weld up before flattening head and block.
Probably putting too much into this 2x but I hate to see a decent body go to waste!
I hope the block is not damaged past repair limits!
Tim <img src="/forums/images/graemlins/cheers.gif" alt="" />
old Toy Man
07 FJ
Re: Engine Serial number Search [Re: w4yn] #774812 12/24/06 12:41 AM
4WD22R Offline
How much is too much? I've put about 3X the amount I paid for the truck into it....lol I did buy it for around $900 though :P
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Engine Serial number Search [Re: w4yn] #774813 12/24/06 02:25 AM
kewlynx Offline
Good luck! Find a decent local machinist. These are pretty bombproof.
www.engnbldr.com They'll be back after the holidays. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Engine Serial number Search [Re: 4WD22R] #774814 12/25/06 02:36 AM
W
w4yn Offline OP
I have built a number of 22r's in last yrar or so but I was not going to do much to this one as it is 2wd. I picked it up from a towing company for 800 with supposedly only a bad clutch. After clutch was alternator, battery mystery misfire and then blown head gasket. Head has a cross threded spark plug, block has some gouges in bore and crank is worn. I will do most of work except crank my self. I have an old boring bar and valve grinder. Will also have head welded around cooling pockets near exhaust valve and resufraced. So for a bargin fix and resell it is getting whole treatment. I also have to find cause of left wheel camber being out of wack!
CU
old Toy Man
07 FJ
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6186 MB (Peak: 0.7088 MB) Data Comp: Off Server Time: 2026-07-09 17:10:41 UTC
