Clutch Disc Orientation? #775254 12/26/06 03:21 PM
mmiller Offline OP
I am replacing the clutch at 165k on my 97 T100. It has been easier than I thought, especially with a big lift and a proper jack. But, before I put the transmission back in, I have one nagging question. Which way does the clutch disc go?
The Hanyes book and a search say to put the spring side (bulky protruding side) toward the transmission. But, I think the original disc is stamped "c/c side" for clutch cover side (transmission side)on the flatter side of the disc. There is a pocket in the flywheel so that the spring pack could mount either way. Some say that having the spring pack toward the transmission allows for better engagement of the splines. How should it be mounted?
Thanks.
1997 T100 4x4 SR5 5spd
Re: Clutch Disc Orientation? [Re: mmiller] #775255 12/27/06 02:31 AM
L
lawnmowerman Offline
Springs towards tranny!I have never seen them any other way.
Re: Clutch Disc Orientation? [Re: mmiller] #775256 12/27/06 04:53 PM
foxtrapper Offline
Interesting. In looking at my 97 factory service manual, they show it both ways. Depends on the engine.
The 5VZ-FE has the "thick" part to the flywheel.
The 3RZ-FE has the thick part to the transmission.
'97 T-100 SR5
Re: Clutch Disc Orientation? [Re: mmiller] #775257 12/27/06 07:35 PM
wsquaredodie Offline
Towards the tranny. Usually will work either way but the throwout bearing engagement will be affected if wrong. Never seen it otherwise.
trafdlo
Re: Clutch Disc Orientation? [Re: foxtrapper] #775258 12/27/06 09:23 PM
mmiller Offline OP
That is why I am confused. I think that is how the stock disc was mounted, but most other people/web info say it should go the other way. I'll wait and see if a more people respond before I put it back together.
Re: Clutch Disc Orientation? [Re: mmiller] #775259 12/28/06 01:12 AM
foxtrapper Offline
99.999% of the time, the spring side of the clutch disc is indeed to the transmission. So the guys saying it's to the transmission side are correct, normally. But that's not the case with the 5VZ according to the toyota factory service manual. If I've got the link working right, the below should be a clickable copy of the page of the fsm showing what I described. Otherwise, the image is on photobucket, fox-trapper, t-100, cl19
[img][image]http://i44.photobucket.com/albums/f48/fox-trapper/t-100/th_cl19.jpg[/img][/image]
'97 T-100 SR5
Re: Clutch Disc Orientation? [Re: foxtrapper] #775260 12/28/06 01:57 AM
L
Page CL-13 97 T100 FSM,the picture on the top of that page is worth a thousand words.You are exactly right,the thick side of the clutch on the 5VZ-FE goes towards the flywheel.
Re: Clutch Disc Orientation? [Re: lawnmowerman] #775261 12/28/06 02:46 PM
mmiller Offline OP
Great. Thanks for the input and picture. I'm glad I didn't put it back together. This also shows the value of a FSM.
Re: Clutch Disc Orientation? [Re: foxtrapper] #775262 12/29/06 01:53 AM
WOW. You gotta be kidding! What were they thinking? Did they need the drive system shortened by that little to do that??? WOW! A Japanese surprise to me. Whowouldthought! Thanks for the info.
trafdlo
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6278 MB (Peak: 0.7152 MB) Data Comp: Off Server Time: 2026-10-21 20:42:24 UTC
