Looking for Trailer Hitch #775452 12/27/06 08:00 PM
TatoHead Offline OP
Fellow Trooper owners,
My new '93 unfortunately does not have a hitch, and I have to put one on. I will not be towing anything heavy, just a very small boat trailer, total weight (loaded) about 500 lbs. Where are the places I should be looking to purchase the hardware?
Can a hitch be installed at home? Does it require welding or heavy drilling? Is there a convenient place to tap the wiring for light connection?
THANKS!
1993 Trooper
"Purple People Eater"
Re: Looking for Trailer Hitch [Re: TatoHead] #775453 12/27/06 08:36 PM
BigSwede Offline
For a Trooper I recommend the Hidden Hitch brand. The crossbar tucks up behind the bumper, very clean look. You can install yourself, pretty easy.
For wiring by far the easiest is to get a Hoppy wiring harness, it will plug-n-play into the pre-existing connector on the Trooper, which can be found behind a large rubber plug up under the drivers side rear fender. You have to lay on the ground to see it, just pull out the plug and the connector will come with it.
Serenity now!
Re: Looking for Trailer Hitch [Re: TatoHead] #775454 12/27/06 08:41 PM
JLEMOND Offline
NO MATTER WHAT YOU MAY BE TOWING ,DON,T BUY A CHEAP HITCH , YOU MAY WANT TO LATER TOW SOEMTHING BIGGER AND HEAVIER AND THE LITTLE 1 1/4 INCH HITCHES WONT CUT IT , BUT YOURSELF A GOOD FRAME MOUNTED HITCH WITH A 2 INCH RECEIVER AND YOU CAN CAN USE ALL KINDS OF DIFFERENT ATACHMENTS, NOT JUST A TRAILER HITCH, AND PARTS FOR THE 2 IN STUFF YOU CAN BUY ABOUT ANYWHERE , AND YES THEY DO ALL BOLT ON , THERE ARE PREDRILLED SPOTS AND THREADED SPOTS ON THE TROOPER FRAME, AND YES IT IS ALLREADY PREWIRED , LOOK UP ABOVE THE LEFT REAR EXHAUST HANGER WHERE THE TAIL PIPE EXITS AND YOU SHOULD SEE A SMALL BLACK RUBBER PLUG STUCK IN THE BODY PANEL ,PULL THE PLUG AND THE FACTORY WIRING HARNESS IS ATTACHED JUST INSIDE THE HOLE, AND YOU CAN BUY A PREWIRED HARNESS THAT IS ALLREADY WIRED TO THE LITTLE 4 WIRE TAILITE ADAPTER READY TO PLUG INTO A SMALL TRAILER . A GOOD HITCH WILL PROB RUN IN THE RANGE OF ABOUT 120.00 WITH ALL THE HARDWARE AND SOME OF THEM EVEN COME WITH THE HITCH RECEIVER AND BALL ,JERRY
Re: Looking for Trailer Hitch [Re: TatoHead] #775455 12/27/06 09:46 PM
TatoHead Offline OP
Wow, thanks for the quick replies!!
I will definately look at going 2". This is all good news, folks! I will let you know how the install goes.
Tato
1993 Trooper
Re: Looking for Trailer Hitch [Re: TatoHead] #775456 12/28/06 02:14 AM
A
all we'll drive Offline
Ever make to Bellingham,Wa? I have a 2" HiddenHitch that I don't use.
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
Re: Looking for Trailer Hitch [Re: all we'll drive] #775457 12/28/06 09:16 PM
TatoHead Offline OP
Dang... I just moved from there (Skagit County) last year..
What are you looking to get for it?
1993 Trooper
Re: Looking for Trailer Hitch [Re: TatoHead] #775458 12/29/06 12:26 AM
A
PM me
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6139 MB (Peak: 0.6924 MB) Data Comp: Off Server Time: 2026-07-13 11:48:07 UTC
