High Crankcase Pressure #775896 12/29/06 06:44 PM
Bijol Offline OP
Howdy y'all!
Here goes my rant over a 1993 Montero 3.0L 6G72 w/ approx 60K mi. swapped engine
Yesterday morning, before taking off, I decided to add 1 qt. of engine oil, since the day before I checked the level.
I twisted off the oil cap with the engine on (recently started), and saw a hint of white smoke coming from the oil opening, which I had seen many times before. When I poured in the oil, the new oil JUST SHOT UP INTO THE AIR. I'd never seen this happen! Is this normal?
I started thinking out my options:
1. Has the PCV valve died?
2. Piston rings starting to go? (haven't run a compression test)
3. Is this normal on a cold engine? (Piston rings haven't expanded yet, causing some normal blowback?)
4. This is normal lubrication system pressurizing in a cold engine...
Please, tell me nothing is wrong! I haven't had a loss in power, or oil leakage thru any gasket. She's running GREAT for the first time in years!!
Re: High Crankcase Pressure [Re: Bijol] #775897 12/29/06 09:08 PM
W
Winston Offline
You added oil with the engine running?
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: High Crankcase Pressure [Re: Winston] #775898 12/29/06 10:49 PM
LRJ4x4 Offline
http://www.ehow.com/how_112872_check-add-engine.html
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: High Crankcase Pressure [Re: LRJ4x4] #775899 12/29/06 11:47 PM
The crankcase AND rocker area in a running engine has constant pressure waves flying around in there, caused by the bottom of the pistons. You can put the palm of your hand over the open fill hole and feel the pulse. Never put oil in a running engine if you can help it unless you just want to add rust protection to all the underhood metal...
PHP: 7.4.33 Page Time: 0.025s Queries: 15 (0.020s) Memory: 0.6030 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-11-18 21:49:21 UTC
