What is this and is it hard to replace??? #776181 12/31/06 07:03 AM
Tygger Offline OP
While changing my brake pads, I noticed the rubber boot was cracked and grease was splattered everywhere.
What is this part called and would you consider it a difficult DIY???
Thanks
1997 Isuzu Rodeo S 4WD
Re: What is this and is it hard to replace??? [Re: Tygger] #776182 12/31/06 07:09 AM
Richard Saylor Offline
Um, that's your cv axle boot. Not necessarily "hard" but can be time consuming, especially if it's your first time.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: What is this and is it hard to replace??? [Re: Richard Saylor] #776183 12/31/06 07:10 AM
This should help ya ... http://www.4x4wire.com/isuzu/tech/CVboots/?
84 Honda XL185S
Re: What is this and is it hard to replace??? [Re: Tygger] #776184 12/31/06 07:12 AM
strawmyers Offline
Isuzu Moderator
Its a CV boot... and there is a write-up on the main page about changing them out HERE. There's nothing particularly 'hard' about changing them, just have to have the correct tools and some ability to use them. I replaced all 4 of my dry-rotted OEM boots with MecaTechs and have been quite happy with them. Good luck!
[edit]Guess Richard beat me to the punch <img src="/forums/images/graemlins/oink.gif" alt="" />
Sean Strawmyer
Re: What is this and is it hard to replace??? [Re: strawmyers] #776185 12/31/06 08:32 AM
Smiley Offline
Until you do replace that CV Boot, it would be a good idea to buy yourself a tube of grease and keep everything inside of there well-lubed.
Also:
Assuming that you haven't already done so - at some point in the future you might want to replace your Drive Flanges with a set of Manual Hubs... With the Flanges, your front driveline is turning ALL-THE-TIME (whether you're in 4-wheel-drive or not).
HTH
Cheers!
Smiley
Six Isuzus, so far... still have three of them.
Re: What is this and is it hard to replace??? [Re: strawmyers] #776186 12/31/06 09:07 AM
<img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> hehehehe
Good call on the mecatechs. I've been eying those myself. Just need to find me that money tree ... who borrowed it last? <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> While I'm asking, who also borrowed the time tree? <img src="/forums/images/graemlins/notooth.gif" alt="" />
84 Honda XL185S
Re: What is this and is it hard to replace??? [Re: Richard Saylor] #776187 12/31/06 06:46 PM
Smiley Offline
Yes - I forgot to offer my high praise...
The Mechatech CV Boot Kit from Matt at Independent4x is one of the best investments I've ever made! --- I honestly can't speak highly enough of it... The full kit makes changing a CV Boot so easy, it's like cheating <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: What is this and is it hard to replace??? [Re: Smiley] #776188 12/31/06 11:56 PM
Tygger Offline OP
Thanks for the info and links. I've never done this so please bare with the stupid questions...
In the mean time, what type of grease do I need to keep things lubricated? Do I just paste the grease in to the opening?
I'm assuming this is the outer boot. Is this all I need to order for $19.99?
http://www.independent4x.com/item.jhtml?UCIDs=839915%7C938630&PRID=955395
What's so special about this kit and why are there 4 boots? (inner and outers for both sides?) If I bought this kit, does it make the first time installation easier? From what I understand, it makes the boot replacements easier after this kit is installed, but I was wondering if it would help with a first time installation as well?
http://www.independent4x.com/item.jhtml?UCIDs=839915%7C938630&PRID=1081216
And lastly, could someone post a link to the manual hubs? Just want to check them out... not trying to get ahead of myself here. smile
Thanks everyone and have a happy new year!
Re: What is this and is it hard to replace??? [Re: Tygger] #776189 01/01/07 09:47 AM
Smiley Offline
You are about to find out where the term 'Smiley Post' came from. --- I've been told that if you ask me what time it is, I'll probably tell you how to build a wristwatch! <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
Here goes:
Just about any automotive grease will do for now - but just so you know, not all grease is created equal... when it comes time to replace that boot, you'll want to use something that's rated and approved for bearings (although, if you buy the Mechatech Kit, it comes with 4 individual tubes of grease - one for each boot in the kit). --- As for what to do with it, yes, you just push a good sized glob of it into opening and coat the CV joint as best as you can (not the shaft-end with the smaller band clamp, but the actual joint-end). --- As you drive, some of the grease will get flung back out - but as long as you keep an eye on it, and keep grease in there, it should be OK until you replace the boot.
After going back and looking at the photo that you posted... that's an INNER Boot -- the outer is located right against the hub, at the other end of the CV, nearer to the tires.
The first link that you posted is for ONE individual Mechatech Boot (that comes with a tube of grease and a pair of band clamps) - and yes, you could get by with just that one boot... for now -- but, at some point in time, you *will* have to replace another one - and having the full kit makes the job a whole lot easier (not to mention the fact that you'll already have 3 spare boots, grease, and band clamps).
THIS is what's so special about the kit:
Until the Mechatech Boot Kit came along, in order to change a CV Boot, you had to remove the CV shaft - or, at the very least, you had to remove one end of the CV shaft... and it was a very messy job. --- But once the Mechatach Boots came along, thanks to the super-elastic compound that they are made of, it became possible to replace a boot WITHOUT removing the CV shaft (provided that you have the full kit - without the kit, they have to be installed just like any other CV boot).
The full kit comes with a handy plastic cone and several tubes of lubricant that are used together in conjunction with the elastic quality of the boot to slide the boot over the hub, without having to remove the CV shaft.
Think of it this way:
Using the cone and the lubricant, the small opening on the top end of that boot can stretch until it is as big as the larger opening on the bottom - and then it pops right back into shape again a-split-second later, once the boot clears the hub... PRESTO! - it's in-place, like magic! --- Then all you have to do is empty the contents of one of the grease tubes, and install the band clamps (the kit even comes with a band clamp tool that's so easy to use that *I* can do it!)
Plus, the kit also comes with a CD-ROM video that shows you exactly how to do the whole job.
(* Note to self: Look into getting a kick-back from Matt for my testimonial endorsement <img src="/forums/images/graemlins/lol.gif" alt="" /> )
Seriously, until you've replaced a CV Boot to old way, you simply can't appreciate how cool the Mechatech Kit truly is... Like I said; it makes the job so easy, it's like cheating.
Although Mechatech created the kit to make an easy job of replacing an outer boot, Rubo and I have talked about the possibility of how the kit could also be used to replace an inner boot just about as easily. --- We havn't tried it yet, but it seems to us that you could cover the band clamps of the outer boot with some heavy tape (duct, gaffing, etc.) to protect the new Mechatech boot form getting torn, and then just slide it right over the inner, then up the shaft, and BINGO - you're there. --- Naturally, you wouldn't want to do so unless you were mighty-darn sure that the inner joint wasn't contaminated with any sand, mud, etc. - but as far as we can tell, it is possible to do, nonetheless.
As for a link on hubs, before you start shopping for anything, you might want to read this:
http://www.planetisuzoo.com/articles.htm?id=80
(* That's about enough typing for now --- Stick a fork in me; I'm done <img src="/forums/images/graemlins/wink.gif" alt="" /> )
HAPPY NEW YEAR! <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: What is this and is it hard to replace??? [Re: Smiley] #776190 01/01/07 10:36 PM
TrooperJ Offline
I didnt know that 97 Rodeos came with drive flanges......could have swore they came with auto hubs.....
I am the lone vote against mechatechs. I like them for ease of installation, but when it comes to durability, i have found that nothing is better than the factory boots. They are much thicker than the mechatechs, and last much much longer. JMHO, YMMV, etc.
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6545 MB (Peak: 0.7855 MB) Data Comp: Off Server Time: 2026-11-16 08:38:59 UTC
