quick lok loacker install need help #776443 01/01/07 09:01 PM
A
anubis Offline OP
I bought a quick lock locker and of course I read the entire little booklet that can with it called manul, with installation procedures. My luck it did not include the install procedures. <img src="/forums/images/graemlins/angry.gif" alt="" />
anyways. Does anyone have a set of these instructions. I think that it is fairly straight forward as for how it goes in.
I have 2 open slots on each side of the fixed center portion as well as 2 opposite sides with just holes.
I need to know if there should be a spring on all four of the as well as a corresponding pin. I put it together that way and it seems like all it is doing is going to stay in the locked position. IE spread out to the ear teeth and locked. I just dont see how it will be normally unlocked with this scenario. thanks for help
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: quick lok loacker install need help [Re: anubis] #776444 01/01/07 09:18 PM
barak Offline
If its similar to the richmond gears lockright locker like I installed, you can go to their website and download the instalation instructions.Even in their little book it wasn't very detailed , you kind of have to guess in certain spots if your doing it right.Try taking a look and see if it helps any at all.I don't have the link handy , but just enter lockright in google and it should list their website.
Re: quick lok loacker install need help [Re: barak] #776445 01/01/07 10:19 PM
A
anubis Offline OP
thanks I looked at aussie lockers webpage as well and it was right onlong the same path as I did. I guess It just seems odd as to the exact operation of the locker and how it eventually went in. thanks for the heads up
Bryan
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5952 MB (Peak: 0.6490 MB) Data Comp: Off Server Time: 2026-05-29 23:48:30 UTC
