How much will MPG increase if I switch to manual hubs? #776591 01/02/07 01:24 AM
MDMarc Offline OP
Curently have ADD on my 94' 22r 4x4 and the mileage isn't stellar. Something went wrong with the 4x4 and I have to switch the vacuum hoses on the valves to get it to work. Thinking about skipping the diagnosis and converting to manual hubs. Any info or product leads is appreciated, thank you...
Re: How much will MPG increase if I switch to manual hubs? [Re: MDMarc] #776592 01/02/07 02:34 AM
A
aj2 Offline
I have used Warn's hubs on my '94 V6 with ADD for many years. I have heard that the OEM manual hubs may be stronger. I do moderate 4 wheeling and haven't had any problems with this setup. I never noticed any significant change in mileage.
I think this setup is better than original since the axles aren't turning all the time, which is easier on the CV joint's and CV boots since I use lowered bumpstops and keep the torsion bars cranked up a little bit.
Re: How much will MPG increase if I switch to manual hubs? [Re: MDMarc] #776593 01/02/07 01:46 PM
ZUK Offline
ZERO mpg increase
mostly stock
Re: How much will MPG increase if I switch to manual hubs? [Re: ZUK] #776594 01/02/07 04:52 PM
Red_Chili Offline
Toyota Section Staffer
At least not real noticeable. Your CV wear will decrease though.
-Bill
Re: How much will MPG increase if I switch to manual hubs? [Re: aj2] #776595 01/02/07 05:02 PM
OOP'S Offline
None but a decrease in wear in the moving parts since they are not turning all the time.
It is not that the stock hubs are stronger it is the way they are fastened. The Warn hubs do not use the cone washers to aligned them and hold them tight to the wheel hub. Under normal conditions, they are fine, but under heavy wheeling conditions the Warns have a tendency to loosen which causes the studs and locating pins to break
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: How much will MPG increase if I switch to manual hubs? [Re: OOP'S] #776596 01/02/07 09:39 PM
bkg Offline
Depends on the truck, it's condition and how you drive...
Saw a 1-2MPG increase in my 86 auto when I switched. My ex-wife's 4Runner was switched right away with no visible change. Some of the Taco folks claim anywhere from 0-2 mpg.
Brian K. Gallus
Re: How much will MPG increase if I switch to manual hubs? [Re: MDMarc] #776597 01/03/07 03:26 AM
A
aj2 Offline
One other thought - could your poor gas mileage be due (or at least partially due) to a vacuum leak from the ADD system?
Re: How much will MPG increase if I switch to manual hubs? [Re: MDMarc] #776598 01/03/07 03:40 AM
ldivinag Offline
about .00000001 increase.
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: How much will MPG increase if I switch to manual hubs? [Re: MDMarc] #776599 01/03/07 03:27 PM
1
1FastSS Offline
0, zip, nada..........
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: How much will MPG increase if I switch to manual hubs? [Re: MDMarc] #776600 01/03/07 04:26 PM
Cholltero Offline
Change the hubs anyway . Like the Chili dude says , less wear on moving parts , thats a good thing. Go to a yard and pick a pair off an old SA. Just got a set myself for the wifes 95gg and swapped it out for 20$.
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-06-10 06:32:20 UTC
