Passport Alternator #777246 01/04/07 10:33 AM
Shuckymomo Offline OP
What is up with these things? This is the 3rd one I'm having to put in since May 2006. Is this a common occurrence? Is there something I can do to prevent having to shell out $100 every 3 months?
Thanks!
1995 Passport Bone stock
Her name is Naomi, that's "I Moan" backwards!
Re: Passport Alternator [Re: Shuckymomo] #777247 01/04/07 01:22 PM
litnin Offline
Thanks!
Well, if you are replacing them for $100 each time, it sounds
like you are using an aftermarket local parts store re-manufactured units.
If that is the case, there is a reason that the parts store
reman's are $100 and the factory replacements are a couple of hundred bucks.
I think your grip is probably with the el-cheapo reman's
that the parts stores sell.
Spend a little extra money, buy a factory alternator or
a quality aftermarket alternator and you probably
will greatly increase the MTBF.
All that is providing your electrical system is in good shape and has no problems.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Passport Alternator [Re: litnin] #777248 01/04/07 01:45 PM
A
anubis Offline
Id love to see those things get mounted higher. What a flawed design on isuzu's part.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: Passport Alternator [Re: Shuckymomo] #777249 01/04/07 01:57 PM
RobG Offline
Yup, this is about par for the course... or you can keep out of the mud/water!
Most part stores offering reman'd alternators give you a limit lifetime warrenty (ie, a single replacement throughout its life)... so, take advantage of this and you'll only be paying $100 for every other one.
-Rob
Re: Passport Alternator [Re: RobG] #777250 01/04/07 03:18 PM
Paddler Offline
I've wheeled mine hard now for 11 years in Mud, Silt, and water. Still have the original alternator with nearly 190,000 miles on it. Buy a new, not rebuilt alt. I'd as well check your entire charging system for possible faults.
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Passport Alternator [Re: Paddler] #777251 01/05/07 12:21 AM
A
anubis Offline
It would probably be a bad omen for me to go out and buy one of the remaned ones as a trail spare huh. I would be certain to have them both break at that point. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Passport Alternator [Re: RobG] #777252 01/05/07 01:33 AM
-Rob
Until I can afford a new one, I'll get the ones with a 6 month warranty (limited lifetime) and then it won't be so bad.
Thanks all!!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6191 MB (Peak: 0.7096 MB) Data Comp: Off Server Time: 2026-10-22 12:10:51 UTC
