Fluid Changes #777281 01/04/07 07:10 PM
Tygger Offline OP
I read the article here about changing the manual tranny and axle fluids. Seems fairly straight forward... but what about an automatic tranny?
Is this a DIY task or would it be better left to a shop?
1997 Isuzu Rodeo S 4WD
Re: Fluid Changes [Re: Tygger] #777282 01/04/07 07:25 PM
Richard Saylor Offline
It's not that hard. The only difference in an automatic is that you'll need to replace the filter at the same time. Pretty simple as dropping the pan, unbolting the old filter, putting the new filter in, sealing/bolting the pan back up, and refilling it with fluid. Nothing truly hard about it.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Fluid Changes [Re: Tygger] #777283 01/04/07 07:32 PM
Bigpoppax2 Offline
It's easy until you see you have no normal way of filling the tranny back up with fluid. You have two plugs in your tranny pan, the lower one is the drain plug the upper one is the fill plug.
You must use a garden sprayer or a fluid transfer pump to pump teh fluid into the tranny. Pump till it comes out on you, then start the truck and get it to normal operating temp, then run the truck through the gears and then fill till it comes out again.
All of this needs done with the truck running and at operating temps. If you ever pull the plug without the truck running you will loose fluid and you will be low.
Joe
Re: Fluid Changes [Re: Bigpoppax2] #777284 01/04/07 07:38 PM
Thanks Joe for the additional info. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I wasn't sure if that year was the non-dipstick one or not.
84 Honda XL185S
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6037 MB (Peak: 0.6598 MB) Data Comp: Off Server Time: 2026-11-16 01:24:17 UTC
