V6 (3VZE) Fuel injector rail adapter for gauge #777401 01/05/07 04:40 AM
A
aj2 Offline OP
Can anybody tell me the size of the Banjo bolt on the fuel rail that I'd need to hook up a fuel pressure gauge?
I think it is an M8 x 1.0 and I have seen one from OTC that appears to have a standard schrader valve type connector on one end for a normal pressure gauge. Has anybody used one? Can this type of adapter be used permanently for installation of a sensor & gauge? I'd like the ability to hook up a test gauge, but ultimately I'd like to have one permanently installed in the cab.
I read that many people apparently drilled & tapped part of the fuel rail on 22RE engines so perhaps I could do that, but this looks like it might work well.
http://amazon.com/s/ref=nb_ss_auto/...;amp;Go.x=0&Go.y=0&Go=Go
Re: V6 (3VZE) Fuel injector rail adapter for gauge [Re: aj2] #777402 01/05/07 05:44 AM
kewlynx Offline
Check out 4Crawler's website
**ubi apis- ibi salus**
Re: V6 (3VZE) Fuel injector rail adapter for gauge [Re: kewlynx] #777403 01/06/07 01:54 AM
A
aj2 Offline OP
Are you talking about this part of 4crawlers website?
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: V6 (3VZE) Fuel injector rail adapter for gauge [Re: aj2] #777404 01/06/07 05:10 AM
4Crawler Offline
Sorry, don't have that info on my web site. Easy to find out, pull the bolt and check the size. I drilled and tapped the end of the fuel injector rail for a fuel pressure sender.
Re: V6 (3VZE) Fuel injector rail adapter for gauge [Re: 4Crawler] #777405 01/06/07 06:52 AM
OOP'S Offline
Why not just drill and tap the bolt you have, or go to a P-N-P and for two dollars you can have as many that will fit into your pocket, do not forget to take a wrench!!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: V6 (3VZE) Fuel injector rail adapter for gauge [Re: OOP'S] #777406 01/07/07 01:21 AM
A
aj2 Offline OP
I picked up some crush washers, so I pulled the bolt (driver's side fuel rail) and determined that it is an M12 x 1.25 in case anybody ever needs to know.
Tapping the fuel rail on this engine would require removing a lot more stuff than I want to pull off right now and even then there doesn't look like there is much room for a fitting. Drilling out the banjo bolt might be a possibility. Picking one up from a junkyard is a good idea in case things don't work out.
Thanks for the replies. Anybody know a good source for crush washers?
Re: V6 (3VZE) Fuel injector rail adapter for gauge [Re: aj2] #777407 01/07/07 03:44 AM
OOP'S Offline
Are they solid copper washers? If yes all you have to do is, re-anneal them. To do that hang them on a bent coat hanger, heat them with a propane torch until cherry red and let cool. That makes them "dead-soft" again and brings the sealing back to them. I have been doing it for years on solid copper head gaskets gas and oil lines on antique motorcycles. Have to it is really hard to find parts for 1913 Indian MC's
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6226 MB (Peak: 0.7135 MB) Data Comp: Off Server Time: 2026-06-07 02:26:21 UTC
