rear windows not working
#777550
01/05/07 12:30 PM
The power rear windows on my 01 sportage quit working. The front work fine. Does anyone know what the problem may be?
Re: rear windows not working
[Re: lesj]
#777551
01/05/07 04:37 PM
Do they work from the drivers console or not work at all? If they do work from the driver and not at each door you've got problems, if they do not work from drivers console but each individually works you have a bad driver's console. More info will help hone in on the issue.
[Re: Lou]
#777553
01/06/07 12:16 AM
The rear windows do not work at all from all switches. The front work fine.
[Re: lesj]
#777554
01/08/07 03:57 PM
This happened to me a year ago. The rear driverside window was stuck (in the up position thank goodness)! Then after about a couple of months it started to work again. Right now it works fine, and sometimes I'm afraid if I use it cause it may get stuck in the down position. <img src="/forums/images/graemlins/confused.gif" alt="" /> I guess I will really never know what happened regarding the window mystery....
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6024 MB (Peak: 0.6629 MB) Data Comp: Off Server Time: 2026-06-24 10:21:24 UTCValid HTML 5 and Valid CSS
