Trooper or Rodeo?? How about Trooper Reliability?? #777623 01/05/07 08:10 PM
I'm gonna be in the market for an affordable SUV. I'm seeing Troopers go for as little as $4000-5000 for 60,000 miles. But, I'm unfamiliar with Troopers. I know the 98 and 99 come standard with 4x4 and a more powerful engine than any previous years, but how does the Trooper fair with the Rodeo? Is it better built? More reliable? Better reviews? Do they all come with transmission dipsticks?
Re: Trooper or Rodeo?? How about Trooper Reliability?? #777624 01/05/07 08:14 PM
BigSwede Offline
Troopers are a great used vehicle value IMHO. Reliability compared to Rodeo is similar. Definitely more room in a Trooper though, 90 cu. ft. cargo volume vs. 88 for a Durango of the same era.
Personally I would get a 97 over a 98+, but some of my reasons have to do with the hubs and transfer case and adaptability for off-road modification <img src="/forums/images/graemlins/notooth.gif" alt="" />
Serenity now!
Re: Trooper or Rodeo?? How about Trooper Reliability?? [Re: BigSwede] #777625 01/06/07 01:22 AM
Jim_Paget Offline
Many, if not most of the major components in a Trooper are the same as the Rodeo. The biggest mechanical differences are the rear axle (the Trooper uses an Isuzu 12-bolt and the Rodeo uses a Dana 44) and the steering, with the Rodeo using a rack and pinion and the Trooper using a recirculating ball.
The horsepower to weight ratio definitely favors the Rodeo, which is you make the assumption that the two are driven identically, then some Rodeo components will be less stressed than the Trooper.
They both use the same transmission, engine, and front axle.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Trooper or Rodeo?? How about Trooper Reliability?? #777626 01/06/07 05:07 AM
troopin34 Offline
just be sure to ask him if he ever ran it low on oil... troopers are japanese and rodeos are american.
Sunkist and Sudefed, Gyroscopes and Infrared
Re: Trooper or Rodeo?? How about Trooper Reliability?? [Re: troopin34] #777627 01/06/07 06:24 PM
jezeric Offline
Isuzu Moderator
In final assembly perhaps, but the engine, trans, and transfer case are the same for both, so mechanically there's no real difference.
James
Re: Trooper or Rodeo?? How about Trooper Reliability?? [Re: jezeric] #777628 01/06/07 08:42 PM
W
Wareagle Offline
Actually, the later model (98+) troopers have different engines (3.5liter), transmissions (drive by wire w/ grade sensing down shift) transfer cases (torque on demand), and rear axles than the 92-97s. These models share very few mechanicals withe the rodeo.
Re: Trooper or Rodeo?? How about Trooper Reliability?? [Re: Wareagle] #777629 01/06/07 09:36 PM
holger Offline
the 3.5 engine is related to the Rodeo's 3.2 - it's basically a bored-over 3.2. The TCs and the rear axles are different. The auto tranny and the front axle are the same.
Close cousin of the Rodeo, 2002-2003 Axiom used Trooper's engine and Trooper's TOD, with Rodeos axles. 2004 Axiom and some 2004 Rodeos introduced new DI engine.
Oleg
Deceased Rodeo'02 4WD.
Re: Trooper or Rodeo?? How about Trooper Reliability?? [Re: holger] #777630 01/06/07 10:18 PM
W
Wareagle Offline
The auto tranny is a different variant of the 4l30e. If you ever drive a later model trooper, you'll feel the difference. They use a gradient down shift feature. IMO, this feature may be one of the reasons that new modesl seem to have more tranny failures.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6194 MB (Peak: 0.7141 MB) Data Comp: Off Server Time: 2026-07-16 04:01:30 UTC
