'98 4-Runner suspension problems/questions #777642 01/06/07 02:20 AM
chisel Offline OP
Hi everyone...my first post here, hope you can help.
The suspension in my '98 4R (161k miles, all on-road) seems soft and mushy, even after replacing the shocks/struts with HD Bilsteins a few weeks ago. I feel it twist a bit when cornering and the wheels seem to skip a bit over certain bumps. The mushy/skipping feeling was the reason I replaced the shocks/struts in the first place, but the Bilsteins didn't help at all. I am a little nervous when driving...it doesn't hold the road like it should/did.
The 4R has had a bit of a harsh ride since new, and I especially noticed a stiffer ride at 99k when I replaced the shocks/struts with Tokico, but couldn't really tell any difference this time with the Bilsteins. Also replaced the stock Goodyear Wrangler RT/S at 99k (with the same), so the current Wranglers have about 65-70k miles (bought used).
Do I need new springs? Some kind of replacement bushings? Something else? What I mentioned above is everything I've ever done to the suspension. Thanks for any help/ideas.
Re: '98 4-Runner suspension problems/questions [Re: chisel] #777643 01/06/07 09:19 PM
boiserunner Offline
You should do a search on here and look for a recall notice on your rear springs.I am the orig. owner of my 98 and yota sent me a recall notice a few(5+) years back. With that many miles new swaybar bushings may also be in order.
1979 cj-7 350sb t18a
1998 4runner sr5 4wd auto
1991 dodge clubcab 4wd manual
1931 ford model A coupe(got decklid lookin for
rumble seat)
Soft and mushy?? [Re: boiserunner] #777644 01/07/07 04:13 PM
first off......if you 've never changed your rear springs or added a 3 inch lift spacer to them......problem 1
your rear is sagging mighty low!
2nd.....check your swaybar bushings with that much mileage because they could be just about to disappear which would cause a mushy feel or roll in turns.
Other than that.a more clear explanation is needed .
Kenny S>
Re: Soft and mushy?? #777645 01/08/07 06:10 AM
chisel Offline OP
By soft and mushy I meant that the body bounces up and down more times than I think it should - think worn out shocks, but it also feels mushy/roll in turns. I'll check the bushings tomorrow...I haven't noticed that the rear is sagging...I'll call the dealer tomorrow about the recall.
Thanks sharrack and boiserunner.
Re: '98 4-Runner suspension problems/questions [Re: chisel] #777646 01/11/07 02:56 PM
boiserunner Offline
I was talking with a buddy that owns a 97 he swears by airbags in-side the springs. Says they help w/ trailer sag and he seems to think they act as a spring damper. Just thought I'd pass this along.
rumble seat)
Re: '98 4-Runner suspension problems/questions [Re: boiserunner] #777647 01/16/07 06:51 AM
chisel Offline OP
Thanks for the info. I ordered the sway front and rear bar bushings last week along with the rear springs...hope to get them installed on the weekend. Will report back on the results.
Re: '98 4-Runner suspension problems/questions [Re: chisel] #777648 02/14/07 08:48 AM
chisel Offline OP
Installed front and rear sway bar bushings along with rear springs and sway bar links - problem solved. Thanks for everyone's help.
Re: '98 4-Runner suspension problems/questions [Re: chisel] #777649 02/14/07 06:21 PM
boiserunner Offline
Nice...glad all is now well.
rumble seat)
Re: '98 4-Runner suspension problems/questions [Re: chisel] #777650 02/19/07 08:51 AM
F
ForOffRoad Offline
Is your idler arm ok? That's a usual problem I find.
Re: '98 4-Runner suspension problems/questions [Re: ForOffRoad] #777651 02/19/07 04:04 PM
Jeff the marmot Offline
The '96 and newer 4Runners don't have an idler arm. They use rack and pinion steering.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6304 MB (Peak: 0.7369 MB) Data Comp: Off Server Time: 2026-11-16 08:55:16 UTC
