Rancho RS44044 ?'s #777668 01/06/07 05:38 AM
9
94redrodeo Offline OP
I got my replacement leaf spring pack for the front it was replaced under warranty. one side is almost like a double wrap the other side is just normal which side should be toward the front of the truck?
I thought this was funny
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Rancho RS44044 ?'s [Re: 94redrodeo] #777669 01/06/07 06:00 AM
Starchild Offline
Sounds like they are pretty liberal on the application of that warranty <img src="/forums/images/graemlins/wink.gif" alt="" />
If the 2nd leaf wraps around the spring eye, its a military wrap. I've heard the wrap should go to the rear, but I'm not sure.
The center pin should be offset. Is the wrap on the long or short side?
What exactly happened to the old spring?
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Rancho RS44044 ?'s [Re: Starchild] #777670 01/06/07 06:10 AM
9
the pin is 23" from the military side 24" from the regualr side
I was just hoping maybe mine were in backwards thats why they were bending.
The old spring. I kept bending it and you know like a piece of wire fold it back and forth enough and it breaks.
Re: Rancho RS44044 ?'s [Re: 94redrodeo] #777671 01/06/07 07:52 PM
Starchild Offline
What part of the spring broke? I assume the side without the wrap.
"SERENITY NOW!"
Re: Rancho RS44044 ?'s [Re: Starchild] #777672 01/06/07 08:57 PM
9
Yes it was the main leaf on the side without the wrap
Re: Rancho RS44044 ?'s [Re: 94redrodeo] #777673 01/07/07 11:49 PM
paulevans76 Offline
shorter side usually goes forward.
88 Troop - Posing yard art
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6125 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-05-29 23:44:00 UTC
