Engine Tick Quiet??? Snake Oil??? #777764 01/06/07 09:18 PM
Tygger Offline OP
Just wondering if those "reduce engine tick" in a bottle work?
1997 Isuzu Rodeo S 4WD
Re: Engine Tick Quiet??? Snake Oil??? [Re: Tygger] #777765 01/07/07 01:56 AM
trooperbc Offline
like what?
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: Engine Tick Quiet??? Snake Oil??? [Re: Tygger] #777766 01/08/07 05:31 AM
F
Fujisawa_Rob Offline
Why, do you have a tick? If it's something like a clogged lifter, maybe a solvent would help, but since you have an OHC???
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Engine Tick Quiet??? Snake Oil??? [Re: Fujisawa_Rob] #777767 01/08/07 03:42 PM
Tygger Offline OP
I have the ticking issue that I assume is common to all 92-97 rodeos.
I don't recall the brand or name, but there were numerous varieties... engine oil additives that claim to reduce or eliminate engine noise/ticking.
Just wondering if this stuff is for real?
Re: Engine Tick Quiet??? Snake Oil??? [Re: Tygger] #777768 01/08/07 07:46 PM
Jonesy Offline
The most common remedy is to flush Sea-Foam, Gunk engine flush through right before an oil change...then run 0W-30 Mobil 1 or other oil. That seems to help clear it up for most.
I can not find an answer for mine. I have done Gunk Engine Flush, Sea-Foam, Royal Purple oil, 0W-30, with no avail. I will keep it up in hopes that a few treatments over time will help.
Just go to know the tick. If you know the sound, it will be ok. Just listen for other irregularities.
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: Engine Tick Quiet??? Snake Oil??? [Re: Jonesy] #777769 01/19/07 04:35 AM
NATO308 Offline
Have you adjusted your valves?
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: Engine Tick Quiet??? Snake Oil??? [Re: NATO308] #777770 01/20/07 12:50 AM
Tygger Offline OP
Nope. I thought I read here that the ticking/tapping noise wasn't from valves on our cars and that it was normal.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6147 MB (Peak: 0.6921 MB) Data Comp: Off Server Time: 2026-11-03 12:24:48 UTC
