Knock-knock... #777883 01/07/07 03:24 AM
RatLabGuy Offline OP
...sensor
Ok so it's been a long week.
Chicken or Egg delimma.
22re, '89 4Runner, A/T. I'm am geting an error code for the kock sensor. Didn't even know, just happened to be setting my idle awhile back and noticed it.
So - do you replace the sensor b/c it's throwing a code, or is its job to throw a code b/c something else is wrong causing the "knock"? Does the sensor actually adjust something?
Why was I setting my idle? B/c it's mighty rough. If I set it at the spec-ed 750 RPMs, once nice and warm, it shakes and rattles the whole vehicle. Engine dosn't sound bad, but when I adjust it by "ear" so that it sounds good, and is more comfy at idle, it's more like 850 or so. Note that at 950(ish)+, it sounds/runs just fine.
Suggestions? Could this be a motor mount issue?
Question Reality.
Re: Knock-knock... [Re: RatLabGuy] #777884 01/07/07 05:58 AM
myyota Offline
The computer uses the knock sensor to listen for detonation
(spark knock)if the computer senses detonation through the knock sensor it retards the timing enough to stop it.
1986 Toyota 4Runner.
Solid Axle Swap, 5'' Lift, 37'' MTR`s, Duel Cases, Detroit Locker Rear, ARB High Pinion Front, 4.88 Gears, Cross Over Steering, Trail Gear Sliders, Addicted Off Road Front Bumper.
Re: Knock-knock... [Re: myyota] #777885 01/07/07 06:24 AM
So - getting a KS code means the best first step is to replace the unit, then? Assuming of course it checks out as indeed plugged in, etc.
EDIT - HOLY CRAP them suckers are pricy. Are they made of gold???
Time to start researchin'...
Question Reality.
Re: Knock-knock... [Re: RatLabGuy] #777886 01/07/07 07:08 AM
VanillaTHUNDA Offline
Yep, check your timing, first and foremost. Vacuum leaks and even a TPS could be at fault, as well.
Re: Knock-knock... [Re: VanillaTHUNDA] #777887 01/07/07 07:16 PM
ignition timing is spot on.
TPS measures out ok.
if it is a vacuum leak (which I won't deny as posisble), i'd think it must be pretty small b/c it does idle ok, just needs to be a little high to be comfy.
Question Reality.
Re: Knock-knock... [Re: RatLabGuy] #777888 01/07/07 08:07 PM
A
Ashokan1 Offline
I got a knock sensor from drivewire.com for about $183. It was the cheapest price I could find. I initially replaced it with a used sensor but it did not solve the problem. So I got a new one for piece of mind.
Of course, the new one didn't improve the situation either so now I'm diagnosing further. You can read my recent posts on this under "Loss of power - Help".
Any other codes thrown??
Re: Knock-knock... [Re: RatLabGuy] #777889 01/08/07 02:13 AM
Any pinging? And what type of plugs are you running? If they're too hot, you could be running into pre-detonation.
Also, I ran into a similar problem a few years back. It ended up being that somehow the knock sensor had backed out a few threads (don't ask me how) and was affecting the harmonics by either rattling slightly or changing the frequency it picked up by altering the contact length with the block. Either way, I torqued it back down and never had a problem again.
Re: Knock-knock... [Re: RatLabGuy] #777890 01/08/07 03:58 AM
bloodbath4runner Offline
so when did it start idling rough? Last time I heard it, it sounded great and the timing was spot on.
You know you're in for a rough night at sea when the barometer does this:
Re: Knock-knock... [Re: bloodbath4runner] #777891 01/08/07 04:53 AM
Basically the next time i drove it and let it get warm enough, I noticed it.
If you remember, I had it set kind of high b/c i did it by ear and didn't know. We set it back down to 750 after playing w/ it and yours.
That was also when I noticed the code.
just to clarify, it's rough but only in Drive, i notice it sitting at stoplights. Just being in Park it idles up enough to be barely noticible.
Weather was crappy today, I'll look at the sensor connection itself tomorrow.
Question Reality.
Re: Knock-knock... [Re: RatLabGuy] #777892 01/08/07 05:19 PM
maxxis85 Offline
All the autos i have driven have the same characteristics, while in park or neutral they will idle higher, than in gear. my thinking is that while in gear the engine is under load weather moving or not, as in park or neutral the engine is not under load. my 2 cents
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6300 MB (Peak: 0.7378 MB) Data Comp: Off Server Time: 2026-06-21 00:11:51 UTC
